Kenmore 24 in. 16293 Built-in Dishwasher Logo
roni roni Posted on Jul 01, 2006
Start flashes and will not begin wash cycle
Cycle will not start, so I pushed 'cancel' button and then re-entered 'start' button, still nothing happens. after a few seconds the start button light flashes
  • rwc1 Aug 12, 2008
    the dishwasher model # is 665. 15867990 serial # FJ2902160 It fills with water, the sensing light come on but nothing happens.
  • Anonymous Mar 29, 2014
    was working ok until removed it for a leak- when reinstalled problem with start. stRT BUTTON TURNS ON AND AFTER short period starts flashing. unit will not start cycle
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 05, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1230
Points
0
My dishwasher Model is 665 15891790 and the serie #FG3907905. After programing my dishwasher and pressing the start button, it fills with water, but when it is due to start the sensing light comes on. I have notice that the ring under the watering arm on the bottom of the machine seams to be cracked. Could that be the problem for the machine not starting its' cycle. Thank you.
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
My washer machines door is locked wont open. And won't wash the clothes in them
  • Unplug your Maytag washing machine for 30 seconds.
  • Plug your washing machine back in, and after 30 seconds, push the "Pause/Cancel/Stop" button two times. Choose a wash cycle.
  • Press the "Start" button until the wash cycle begins to ensure that the washing machine is functioning properly
  • 0helpful
    KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
    Hello
    first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
    normal wash ,, hi temp scub
    if either of these resets the control the you will have to replace the control panel / thanks
    1helpful
    I am trying to start a cyle and everytime i push the cycle button it does not light up and the quick rinse button comes on and flashes nothing works at all if i push heavy wash it comes on and nothing...
    You haven't told me how many times the light flashes, but I will take a guess that this is an error code associated with the water entering the machine being too cool. I believe the machine expects the water to enter at 110 degrees F (43 Degrees C).
    To clear the error, press "Heated Dry" then release, then press "Normal Wash" then release and repeat this sequence until all the lights on the machine go solid green. Once this happens, hit ""Cancel" and the machine will reset.
    The fix for the root of the problem is to increase the temperature of the incoming water in future (Turn up your water heater temperature a little)
    2helpful
    Can't get washer to start again after pushing pause/cancel button
    sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
    1helpful
    Kenmore Ultra Wash Dishwasher LIghts are blinking....
    I suspect for either of these units that the timer control boards are bad.
    Jan 24, 2009 • Dishwashers
    Reset wash cycle
    Changing Cycles, Options and Modifiers
    Not all Options and Modifiers are available with all cycles. Cycles,
    Options and Modifiers can be changed anytime before HOLD TO
    START is selected.
    Options and Modifiers can be changed anytime after HOLD TO
    START is selected and before the start of the selected Option or
    Modifier.
    To cancel a cycle and select a new cycle
    1.
    Select PAUSE/CANCEL twice.
    2. Select desired cycle.
    3. Select the desired OPTIONS.
    4. Select HOLD TO START (for approximately 1 second) to
    restart the washer at the beginning of the new cycle.
    To cancel a cycle
    1.
    2. The washer powers down, the door unlocks, and clothes can
    be removed.
    NOTE: If the water level or the temperature is too high, the
    washer will drain automatically before the door unlocks.
    To change Options or Modifiers after the cycle has started
    1.
    Select PAUSE/CANCEL.
    2. Select the desired OPTIONS or MODIFIERS.
    3. Select HOLD TO START (for approximately 1 second) to
    continue the cycle.
    To drain the washer manually
    1.
    2. Select DRAIN/SPIN.
    begin the drain.
    4. When the spin is complete, the door unlocks. Items can be
    removed from the washer.
    Kenmore He4t- pushed cancel to add at start of load, now nothing but flashing lights
    The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. Sometimes this is all that is required to "cure" momentary "glitches". If this does not fix your problem, please post back and let me know. Hope this helps you.
    18helpful
    2answers
    I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
    Top Kenmore Dishwashers Experts
    vince
    Paul Carew
    NOEL
    NOEL
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
