Keeps going to standby
SOURCE: Need remote code for Sylvania 32" LC320SS9 for Dish controller
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Let me know how it goes and please rate this solution
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: remote codes don't work
Set Mode switch to TV
Press and Hold Mute and Select buttons AT THE SAME TIME UNTIL LIGHT BLINKS TWICE
Enter code 10054
If that doesnt work here are more codes. You must start over each time.
10171
10096
10187
10020
10381
10024
10030
11314
10186
Let me know how it works out for you.
SOURCE: how do i hook my 32 inch sylvania model lc320ss9
This set has a VGA input connector on the rear panel, so you can just plug in a cable from the PC to the TV. You can download a copy of the owner's manual and get more connection information at Sylvania's site here.
SOURCE: vertical lines in my sylvania lcd tv
They go away after 10 minutes of what? **** She Wrote? Dancing with the Stars? Or simply being powered On? You have some cold solder joints on one of the PCB boards. Once they heat up they work perfectly. The only way to fix this is to have them reflowed by a tech with a soldering tool or have the board replaced. Good luck! Cheers
SOURCE: I have a dish network satellite dish and the
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the TV Mode button on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
