YONGNUO RF-602 RX Wireless Camera Remote Control Shutter Switch for Nikon D70S D80 Logo
Vera McCormick Posted on Feb 01, 2012
User manual for yongnuo wireless flash receiver RF-602RX
Can not get it to work. no instructions.
I have a AKG Harman SR45 Perception Wireless headset and receiver. When I plugged it in to use for a class, the RF light wont come on. In the window where the channel shows it has an E there.
The user manual I have examined may not be the exact same unit you have but the principal of setting frequency channels may be Similar for your unit.
the receiver has eight selectable channels .
Do you have the user manual as you need to select the channel your headset is using .
if not get it here here https://www.manualslib.com/download/1114396/Akg-Perception-Wms45.html
page 27 of user manual describes how to set channel number
page 11 of the pdf file
3helpful
2answers
Nikon d3000 flash trigger circuitry
Save your money from buying the Wein.
Get the Yongnuo RF-602 or RF-603
And become a better flash photographer.
You will be shooting like a pro rather than advanced photographer.
More help, send me an email.
[email protected]
Apr 01, 2012 • Cameras
Operating instructions yongnuo yn460
You may download the manual here.
Jan 24, 2012 • Cameras
I have model CE 0560. New batteries are in. Pressed the dricer button which lights up. The redlight on the bottom of the mouse is on and flashing. The controls on the mouse do not respond.
You will need to follow the manufacturers instructions on setting up the mouse. Here is a copy of the instructions for download (Below is a viewable copy). Based on what you indicate, it is possible that the drivers are not loaded for the usb reciever or that one of the installation steps was not done correctly or completely. Please review the instructions and start from the first step.
Here are the instructions:
Targus Wireless RF Mouse USER’S GUIDE Making Your Mobile Life Easier.® Visit our Web site at: www.targus.com Features and specifications are subject to change without notice. © 2004 Targus Group International and Targus, Inc.. 400-0111-001B
System Requirements To use the RF mouse, your computer must meet the following hardware requirements and run one of the operating systems listed below. Hardware • PC with a Pentium® processor or equivalent • USB interface • Mouse • Receiver • 2 AAA batteries • Three inch USB extension cable • Carrying pouch Targus Wireless RF Mouse Operating System • Windows® 98/Me/2000/XP NOTE: The third button and the scrolling wheel only work with the operating systems listed above. If you use the RF mouse with a different operating system, it will lose its enhanced features and function as a standard, twobutton mouse.
Connecting the Mouse Receiver To connect the mouse receiver: 1 Plug the USB receiver into an available USB port on your computer. 2 Your computer’s operating system identifies the receiver and begins installing the default driver. Follow any on-screen procedures to complete the default driver installation. Using the RF Mouse Installing the Batteries 1 If the mouse is on, slide the on/off switch on the bottom of the mouse to the “off” position. 2 Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off. NOTE: The battery cover is also the top cover of the mouse.
Targus Wireless RF Mouse 3 Insert the supplied batteries, making sure that the positive (+) and negative (-) ends of each battery match the polarity indicators inside the battery housing. WARNINGS: When replacing the batteries, you may use alkaline or other heavy-duty NiMH batteries. Never use an alkaline with a NiMH battery in a device. Avoid mixing new and used batteries in a device. 4 Slide the battery cover back into position until it “clicks” firmly into place. 5 Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position. The optical sensor, located on the bottom of the mouse, glows red. Establishing a Communications Link The RF mouse has 256 identification codes that allow the mouse and its receiver to operate without interference from other radio frequency devices. After your computer detects the USB receiver and the driver software is installed, you must establish a communications link between the mouse and its receiver BEFORE you can use the mouse. To establish this link, you need to set the identification code so that the mouse works properly. To do this, follow the instructions below: Make sure that your computer is turned on and has detected the USB receiver before you establish a communications link. 1 Press and release the link button on the receiver.
Targus Wireless RF Mouse Receiver The USB connector rotates 90 degrees to facilitate easy connection to your computer. The receiver’s status light blinks when the receiver is activated. 2 Press and release the reset button, located on the bottom of the mouse. You are now ready to use the RF mouse. Mouse Power Management To power the mouse on and off, slide the on/off switch at the bottom of the mouse to the desired position. efafd91.jpg
Mouse When power is on, the mouse goes into "sleep mode" after 8 minutes of no use. To activate the mouse, touch the sensor strips on the side with your hand. To save battery power, turn off the mouse while traveling or when you’re not using it. CAUTION: Turning off the mouse will require you to synchronize again the next time you turn it back on. 90° rotation Status light Link button Sensor strips Low battery indicator
Targus Wireless RF Mouse Operating Hints For optimal performance and RF reception: • Place the receiver at least 8 inches (20 cm) away from all electrical devices, such as your monitor, speakers or external storage devices. If necessary, use a three-inch extension cable to keep the receiver away from the computer. Plug the receiver into the extension cable, and the extension cable to the computer. • Avoid using the RF mouse on a metal surface. Metals, such as iron, aluminum or copper, shield the radio frequency transmission and may slow down the mouse’s response time or cause the mouse to fail temporarily. • The RF mouse will enter a suspend mode at the same time your computer does. To activate the mouse, touch the sensor strips on the side of the mouse. • If your computer has a metal case that contains aluminum or magnesium, use the RF mouse to the side. The display panel may interfere with the radio frequency signal if you use the mouse directly in front of the computer. • Never use the RF mouse on a glass or mirrored surface as these surfaces will cause the mouse to fail temporarily. • To maximize battery life, use the RF mouse on a white, or light colored surface. Dark surfaces cause the mouse’s light emitter diode (LED) light to glow brighter, which causes the battery to discharge more rapidly.
Targus Wireless RF Mouse Sleep Mode • The mouse’s sleep mode feature activates after 8 minutes of non-operation. • To wake the mouse from sleep mode, touch the sensor strips on the side of the mouse. • When the battery charge is running low, the battery indicator light at the end of the mouse glows blue.
Targus Wireless RF Mouse Troubleshooting What do I do if the RF mouse does not work? • Make sure that the polarity of the batteries is correct. The positive (+) and negative (-) ends of each battery must match the positive (+) and negative (-) connections in the battery housing. • Check that the receiver’s USB connector is firmly attached to the USB port on your computer. • Verify that the device drivers are installed. • Make sure you have established a radio link between the mouse and its receiver. See “Establishing a Communications Link” in sections above
Receiver for my RF wireless deskset is flashing constantly
If the mouse and keyboard are working, and the receiver is still flashing constantly, then it's probably just indicating that the receiver is connected to the keyboard and mouse.
Please introduce HP wireless Mouse and how to work
The mouse is an extremely popular technology to interact with your computer. While the majority of mice are connected directly to the computers peripheral input via a cord and are powered by the computers main power, wireless mice are becoming extremely popular to give computer users cordless accessibility to their mice and to interact with their computer.
Wireless mice usually work via radio frequencies commonly referred to as RF. RF wireless mice require two components to work properly a radio transmitter and a radio receiver.
RF- Radio Frequency
2answers
Targus RF PAUM005 Mouse Not Working
do you have the CD that came with the hardware???
seems like the PC can't communicate with the hardware. although it see something out there, but it doesn't recognize what it is.
even the machine is says this device is working porperly, you still need to install the driver, and the configuration for the device. that's why the receiver doesn't flash.
try to install the drivers and the configuration application.
Top YONGNUO Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a YONGNUO Home Security Expert? Answer questions, earn points and help others
