2001 Chevrolet Tracker Logo
israel zuniga Posted on Feb 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ligth obd code p0406
raj somaiya
Level 3:
  • Chevrolet Master 5,370 Answers
  • Posted on Feb 26, 2012
raj somaiya
Chevrolet Master
Level 3:
Answers
5370
Questions
0
Helped
3570968
Points
14579
For OBD code problems check the list of help links below. Click the link below to go through its procedure.--------------Diagnostic Code P2195?http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html--------------Diagnostic code P1330?http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html------------Diagnostic code P0700, P1330, P1121?http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html-------------shows error code P1330?http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html--------OBD code P1330?http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html------------OBD code P01300?http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html--------------OBD code P0768?http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html------------Evaporative Emissions System codes details?http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html--------------- Engine Misfire codes?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010?http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html-------------Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error Codes?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.------
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540 continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
-----------This will help.Thanks.
My 2000 lincoln navigetor ligth air bag seat driver on
get the OBD codes read . this should locate the sensor/switch causing the issue
2006 lincoln ls with po406 code
This code is related to the EGR system. Inspect the vaccum lines around the EGR valve and see if there are any breaks. These get brittle with age. It may be stuck open or closed as well, and if this is the case you will need to replace this. Go to rockauto.com and you should be able to find it for around $100.
http://www.obd-codes.com/p0406
Error p 0406
Diagnostic code p0406 on dodge durango
The P0406 means "Exhaust Gas Recirculation Sensor "A" Circuit Low", maybe you have known where is the problem.
_________________
autocom newest version
1helpful
What is error code 0406
OBD-ll Code P0406 - EGR Sensor "A" circuit "High" .
The EGR sensor is part of the EGR valve, the valve has failled, need a new one, very common. The pintle sticks or the sensor it self goes bad either way install the new one, disconnect the battery to relearn the pintle position and you're good to go.
Hope helps.
6helpful
3answers
OBD II code P0406. Any solutions?
you have a egr issue. It could be the valve needs replacing but without a diag it could be an electrical issue like a broken wire. Will need a snanner to check it out correctly
2answers
Replace egr sensor, error code p0406
I have fixed the problem foe now.
thank you
2helpful
P0406 Code
It is for the Exhaust Gas Recirculation (EGR) valve.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
