Fan inside blower unit stuck or seized. The compressor noises are because liquid refrigerant is coming back because it's not picking up heat from the room. Check/ clean the filters and spin the motor of the fan WHILE SWITCHED OFF. If it spins, it's probably the fan capacitor. If it doesn't, get a new fan
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
I have a 2000 pontiac grand prix with a digital climate control system.
The heat quit working, it doesn't blow out any heat. Now that it is warm
outside the air stopped blowing out any air. The digital temperature on
the climate control is not correct. When it states that it is below 30
degrees on the ext and it is warm outside the air wont be cold. Once it
starts going above 30 degrees the air gets colder. Today the blower stop
working all together. Was told it maybe the climate control unit was
bad. You can hear the door opening/shutting when you switch the temp
from cold to hot. But there was no heat blowing out whatsoever in the
winter time. Could you please give me your opinion on whether or not it
is the climate control unit or something else?
Processor fans are setup to nearly always blow air inward onto the heat sink that sits on top of the processor. The heat sink pulls heat off of the processor and the processor fan blows air onto the heat sink to cool the heat sink so that it can pull more heat off the processor. However, read the following link to see that it probably doesn't matter that much which way you put it: http://www.overclock.net/faqs/14695-opinion-****-vs-blow-way-do.html
I would definitely set it up with the processor fan blowing inward onto the CPU. If you're experiencing overheating you can try switching it to see if that helps. Use a program such as SpeedFan to monitor your computer's temperatures.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Look at the wires that go to the compressor and make sure they are not burned off. Inspect the capacitor tops for swelling and loose or burnt wiring. Also check the connections coming from the controls. May have a wiring problem or even a bad compressor. How old is the unit?
