Sylvania SRT2232S 32" TV Logo
luther griffin Posted on Jun 30, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sleep set the sleep timer and went to bed. Tv went to sleep normal but have not been able to get it to turn on since. Nothing no sound no picture. can you get it out of sleep mode griff
Anonymous
Level 3:
President:
  • Master 3,130 Answers
  • Posted on Jun 30, 2006
Anonymous
Master
Level 3:
President:
Answers
3130
Questions
5
Helped
1650331
Points
8439
If you unplug the unit for an hour or overnight, it should go out of sleep mode. If this dosent work then its not in sleep mode and the set has a problem in the power supply or the sweep circuit. Sorry you should seek a pro to assist you in this repair. Good Luck
2answers
Sleep timer shuts off picture but not the sound
It's possible that the power outage could have affected the TV's settings, including the sleep timer function. You may want to try resetting the TV to its default settings to see if that resolves the issue. To do this, you can usually find a "reset" or "factory reset" option in the TV's settings menu.
If resetting the TV doesn't work, it's possible that there is a software or firmware issue with the TV. In this case, you may need to contact Hisense customer support or bring the TV to a repair shop for further diagnosis and repair.
Black screen and no sound after a few minutes.
First, here is a copy of your manual in case it is missing.
http://www.warrantyweek.com/library/ww20061219/panasonic-th42px60u-manual.pdf
Next, check the settings of the sleep timer.
Select on the remote:
Menu.
Timer.
Sleep.
See if there is a time setting in there. You may also find a shortcut from the remote labeled "Sleep".
If this fails to resolve the issue, you can always reset to factory defaults. To do this, select from the remote:
Menu.
Setup.
Reset.
Hope this helps. Be sure to let us know how this helped.
1helpful
2answers
I pressed the sleep button by accident and the pic and sound went off and the stand by/timer red light started blinking. what does it mean?
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
Once you have this code,please post it.
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Power
if the tv set have no sound no picture, they call it dead set your tv need a repairman technician to trace your tv what was part was damage. but if your tv has standby mode mybe you entered the timer code.
5answers
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
