Posted on Nov 26, 2017
My Sony Walkman mp3 player NWZ - S540 fell off my stand in the bath room and into the sink while water was on. What do I do I have had it for almost 2 years and now it is not working right
I don't know what to do. I don't have any rise to put it in and I picked it up really fast once it happened. It will turn on but sometimes it is frozen and then it will move on its own. Or it will be unplugged and the battery icon is still going. It wont connect to my computer at all. I dont know what to do.
willirl45
Level 1:
  • Contributor 26 Answers
  • Posted on Nov 26, 2017
willirl45
Contributor
Level 1:
Answers
26
Questions
0
Helped
5782
Points
76
Try removing any covers that you can without breaking anything, then fill a container with uncooked rice and push the player into the rice and cover the container. Leave it like this for a week or so.
5 Related Answers
A
Anonymous
  • Posted on Oct 07, 2008
SOURCE: NWZ-S615FBLK sony
i love you guys....worked like a charm...
Anonymous
  • 62 Answers
  • Posted on Feb 26, 2009
SOURCE: sony mp3 player model no.NWZ S616F - screen frozen
hit the reset button with something sharp at the bottom of the walkman
Anonymous
  • Posted on Mar 23, 2009
SOURCE: remove write protection on a walkman nwz-s616f
I had the same problem after using this product for a month, suddenly it showed the warning of write protection.
I even contacted the sony customer center but to no avail. their answer was of no help at all. so here is what i did to make it work: 1) First install "QuickTime version 7.2" or later (you can download it from torrent if you are unable to register it, i.e. with a crack) 2) Then install "Windows Media Player 11 " (you can download it from torrent if you are unable to validate it, i.e. if WinXP not original) 3) Now install "Media Manager for WALKMAN" (a compatible software provided by the sony company to interact or communicate with the walkman), freely available for you to download at sony's website.
After the installation, connect the walkman to your computer. Now it should easily add or delete data from you walkman using this software or without it as well.
Anonymous
  • Posted on Apr 24, 2009
SOURCE: Battery on Sony Walkman NWZ-E436F
ok, just tried something with maybe a solution....
I was connected via an usb hub to my laptop, then it said battery is full, it apparently didn't charge.
When i connect my usb cable directly to my laptop it started to charge again!!.
My usb hub is not connected to a adapter so all power comes from the USB port, this may be not strong enough to charge your walkman.
Try this (so directly connect to your desk / laptop) it may work!
regards
me
Anonymous
  • Posted on Oct 29, 2009
SOURCE: My Sony Walkman NWZ E438F is frozen and I just
No. The only thing it will erase is the time, but that's easy to fix. Reseting it shouldn't do anything to your music at all.
2helpful
3answers
I have a Sony b152f which fell in water, while i try to shake it accidentally it is switched on ! Will it Work ?? What is the cost of the Battery ??
Unfortunately if the Walkman is not serviced within the hour of the accident it is already to late. When water enters it corrodes the ic pins and eventually works it's way in the ic casing and other critical parts causing short circuits, even if it worked! it will go into cascade failure in a matter hours, days, or weeks depending on the situation. I recommend not sinking any money into it because it will be wasted. Any electronic boards must be washed in rubbing alcohol and other parts that are important to get rid of any water residue, and the units have to be completely dis-assembled to have a fighting chance of success.
tip
How to transfer songs, videos and pictures to a Sony NWZ Series Walkman Players
It is so easy to transfer music files, videos and pictures to a Sony Walkman using Windows Explorer. Of-course, it is almost same for other manufacturer products as well. You can use theWindows Explorer to transfer files (music, images and videos) to a Walkman Player. Once you connect the Walkman Player to the Computer, it will display asan additional storage media under My Computer. Please follow the below steps toaccess the Walkman Player using Windows Explorer.
  • Click Start and then click My Computer .
  • In the My Computer window, under Other , double click the icon for your portable player.
  • In the My Computer[Name of your portable player] window, double click Storage Media .
  1. Now, drag and drop the music files or folders into the MUSIC folder.
  2. Drag and drop video files or folders into the VIDEO folder.
  3. Drag and drop picture/image files or folders into the PICTURE or DCIM folder.
Now, the only thing you want to make sure isthat you're transferring compatible files to the player to use in it.The video files should meet the following requirements.
MP3 is fine for audio and for images, jpeg wouldbe good.
I hope this instructions help you to transfer files to the Sony Walkman player.
How to transfer songs, videos and pictures to a Sony NWZ Series Walkman Player. How to transfer files to Sony MP3 player. Transfer videos Sony player. Sony video walkman player transfer videos. Unable to transfer videos. Videos does not play in Sony video. Sony mp4 player, how to transfer. NWZ-A829BLK NWZA829 NWZ-S615F NWZ-S610 NWZ-A820 NWZ-S545 NWZ-E436 NWZ-A818 NWZ-B142F NWZ-A801 NWZ-B135F NWZ-S710F NWZ-A728 NWZ-W202 NWZ-S610 NWZ-E438F NWZ-E435F NWZ-B130F NWZ-X1000 NWZ-A826 NWZS615F NWZS610 NWZA820 NWZS545 NWZE436 NWZA818 NWZB142F NWZA801 NWZB135F NWZS710F NWZA728 NWZW202 NWZS610 NWZE438F NWZE435F NWZB130F NWZX1000 NWZA826 NWzE354BLK NWz-E354BLK NWzE354 NWzE354B NWz E354BLK NWz E354 BLK Sony NWzE354BLK NWzE353BLK NWz-E353BLK NWzE353 NWzE353B NWz E353BLK NWz E353 BLK Sony NWzE353BLK NWzA545BLK
NWzS545BLK NWz-S545BLK NWzS545 NWzS545B NWz S545BLK NWz S545 BLK Sony NWzS545BLK NWzS544BLK NWz-S544BLK NWzS544 NWzS544B NWz S544BLK NWz S544 BLK Sony NWzS544BLK
Hello, I'm not able to play files on my Sony walkman NWZ-B133F MP3 Player. Please help, the error being shown is "Boot Eeror"
boot_error
Yo tenia este problema y esta solucionada.
Sigue los siguientes pasos.
1- Baja firmware nwz-b133f (firmware nwz-b130 v-1.01)
2- Baja firmware nwz-b103 (firmware nwz-b100 v-1.3)
3- Primero ejecutar firmware nwz-b100 , conecta tu walkman
cuando pida conectar por favor el dispositivo luego pida formatear
el dispositivo vas a perder toda la informacion has click en
aceptar.
4- No desconectas tu walkman espere hasta que formatea
todo y carga todas su datos , este era necesario para el puro
formato porque el firmware nwz-b130 no lo hace.
5- Desconectas tu walkman y vas a ver que no enciende (logico no
es su firmware)
6- Ahora ejecutar firmware nwz-b130 , conecta tu walkman cuando
pida conectar por favor el dispositivo , no desconectas tu
walkman espere hasta que carga todas su datos.
7- Cuando termina desconecta tu walkman de manera segura.
8- Listo como nuevo.
Saludos Quicktronics aqui desde mexico.
Espero que la gramatica esta bien , soy Holandes.
My sony walkman NWZ-A726 4GB fell into water and it does'nt work now...
You should have immediately turned it off after removing from the water and let it dry for a few days. But now you should open it up and clean all the conatcts with alcohol and see if it works again. There is only a slim chance that it will.
12helpful
2answers
Driver required for sony walkman ipod NWZ-B142F
sony ipod no nwz-b152 not detected on my desk top have xp
1helpful
My nwz-e345f walkman has water in it how do i get it out
Put it in a bag of rice leave it in thier of a day or so an take it out and the water sould be gone
Broken walkman
well, my **** just fell off.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
