Need instructions on how to operate and maintaiung Oreck model 12GU Air Purifier
First of all, thank you very much Joe for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.oreck.com/PUG/Air-ProshieldPlus-AIR12GU-userguide.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
SOURCE: Oreck XL air purifier (Tower Model)
check for an eventual short or lose contact, if it is all right then you brobably need to replace the contol board
SOURCE: Oreck XL air purifier motor failure
My Orek was making such a bad noise that my wife was going to sell it at a garage sale, I'm glad she didn't. It takes about 20 minutes to fix. All you need is a phillips screw driver, can of compressed air (or air compressor) and a can of silicone spray.
Pull out the filters and turn the unit upside down. Using a phillips screw driver unscrew the 9 screws holding the bottom to the top. remove the bottom. Use care as to not damage the fan. The fan will stay attached to the motor , pull on it and use a good cleaner like 409, Simple Green or a similar product. Wash clean and dry. Next get out your air compressor and clean everywhere, see the silver bearing holders on the side of the motor? Get out your can of silicone spray and give a good squirt on both bearing (close to the shaft. also spin the motor with your hands. See the large thing attached to the shaft? Those are the windings. See the metal housing the winding spin close to? Spray the silicon in there, a good amount. Make sure you didn't get any silicone on the end of the motor shaft where the fan sits on. If you did get some nail polish remover or acetone and wipe clean a few times. Then reassemble.
My Orek was horribly noisy, now it's quiet. My wife says is beeter than new.....
SOURCE: Cleaning the top of the oreck air purifier
what i normally do, is i take off the top of the and remove the filter, the metal dust catcher, and the back filter... i was the 2 filters and rub them down. then with the metal dust catcher i take a butter knife. wrap it in a clorox wipe (making sure that no metal is exposed to scratch) then i feed it through the metal dust catcher one at a time to clean it. It took me 5 wipes to clean the whole thing. when the wipe comes out black then i rotate it. As for the top of the machine. there are 2 screws that i removed to get to the fan. when they were out i used a can of air (like you would clean a computer with) and blew out the fan... it took care of all noise and it runs just like the day i got it.
SOURCE: Oreck Air Purifier. Need to take it apart to clean the collection
i just used a butter knife wrapped in a Clorox wipe... being careful not to have the metal show so that it will scrape. when the wipe comes out black, rotate the wipe so that it will be able to clean. I used 5 wipes rotating. I could not figure out how to open the thing either so this was my solution.
SOURCE: I need a manual for the Oreck XL professional air
How do I open the Oreck XL to get the filter out to clean it?
How to down load an instruction manual for Oreck 12GU Air Purifier
TNX for your promt reply and help.
