100 song bank keyboard
SOURCE: casio ctk 496 keyboard
Unplugging and taking batteries out for 15 minutes should reset it back to factory.
SOURCE: im looking for a manual for the casio ctk 601
http://www.usersmanualguide.com/manuals/casio/CTK-601_CTK-611.pdf
here u can download manual...
SOURCE: Power input needle snapped on Casio CTK 1000
The answer is repair shop if you don't have tools or experience with soldering. If you do it is simple to take it apart and take the old supply jack out. Take it to an electronic parts supplier so they can match a new one up for you. Make sure that the holes in the circuit board are clean and free of broken pins. Make sure that the traces leading to the holes are intact. Do not use too much heat or they will separate from the board. It might help to take the adapter with you as the jacks and plug have to match in size.
SOURCE: not able to connect to USB MIDI of my Casio CTK 810i
On reading specs, use of the USB is NOT supported on a MAC or on other than the 32 bit version of Vista. If you happen to have the 64 bit Vista, it won't work. All the other versions of Windows seem to be supported..
SOMETIMES one must install the software BEFORE connecting the USB cable to the unit. SOMETIMES one must install the drivers in SAFE MODE. These things are ridiculous, but some of the quirks of Windows are stupid.
