The treadmill counts down from 3 then comes up e09 and won't start. What can I do?
Search using youtube for video help.
https://www.lifespanfitness.com/fitness/resources/articles/what-does-your-treadmills-error-code-mean
Treadmill Error Codes and Troubleshooting
May 21, 2015
Please refer to the following treadmill troubleshooting guide if your LifeSpan treadmill or treadmill desk is displaying an error code. If after trying the suggested solutions your treadmill is still showing an error please contact our customer service department at 877.654.3837 x4 or fill out a customer service request form.
E09 error suggests you contact customer service for further assistance.
My motorized Treadmill is showing error E09 how can l clear the error?
SOURCE: asi image pro 2 treadmill error code 2
Loss signal or No Speed: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
SOURCE: 3 yr old Smooth Fitness 7.1HR Pro won't Unfold
rosenfelddav, did you ever find the solution to your problem. I have the same exact issue and would like to know how you fixed your issue.
SOURCE: e01 code on pro fitness treadmill
If your treadmill is connected via extension cord, then try connecting it directly without extension and check.Also if that is not the case, then it can be issue with lower board or the display panel board. ---------- Also what is exact model of your treadmill.It also depends upon that.-------- Keep updated.Thanks.Helpmech.
SOURCE: My treadmill won't start. Help pro firm at 500
Observe carefully and follow the step:
http://www.youtube.com/watch?v=N6Yg5S0WML8&NR=1
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
Of course you must shure the breaker from your house is Not Tripped, reset anyway
and test it.
Dear Sir:
I will try to help you, please use the steps with patience and carefully: You must need some basics tools; Included Dvom (Digital Voltemeter).
Instructions
Things You'll Need for to Reset Code:
1.
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
Press the "ENTER" button three times to access the treadmill's error log.
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
To view the treadmill
