Maax Pearl By  CS60wh Pearl CS60 in White Logo
ryan Posted on Jan 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pearl cs60 instructions - Maax Pearl By CS60wh Pearl CS60 in White
kenneth njonjo
Level 3:
Top Expert:
  • Master 1,575 Answers
  • Posted on Jan 31, 2012
kenneth njonjo
Master
Level 3:
Top Expert:
Answers
1575
Questions
Helped
365520
Points
4558
Hi, we use the plantronics cs60 headset at my place of work and the earpiece stopped working so i have changed it for another one and i have paired them together but now when i pick the ear piece up the...
It would depend on what headset you actually purchased. You say CS60 but it may be the Plantronics CS50 or CS55 headset. The headsets are not interchangeable. If you are not sure what headset you have, simply look on the bottom of the base for the part number. On the headset you can read what part number that is by very carefully looking under the battery. Here is a link to open the battery.
Here is a link to the CS60 instructions to replace the battery.
I think that if the base and the headset are the same it might be that you may need to subscribe or pair it together again.
Here is a link to the CS60 subscription and pairing instructions.
Good luck from Headsets Direct!
How can i pair a Plantronic cs60 with a playstation 3? Can you discripe it in steps?
The CS series of Plantronics headsets can only be used with telephones, using telephone cords. I do not believe it is possible to use this item on any video game system or non-landline telephone.
2helpful
The pump surges where's the impeller
if your pump is surging then you do not have enough water in the bathtub or you have a jet that is blowing air into the suction fitting. this happens a lot when a jet faces the suction and the air control is wide open. the suction pulls in too much air and causes the pump cavitation (surging). Try pointing the jet opposite the suction cover upwards and see if that doesn't solve the problem.
Plantronics cs60 cordless headset not working properly with Mitel 5220 ip phone. Cant switch between handset and headset. When you lift the handset sound comes from the headset. The same headset works fine...
I'm sorry for being long on my answer here...
The bad thing here is that the CS60 is not a Mitel approved/supported headset. The only headsets that are approved for Mitel Superset or Mitel IP telephones are the Plantronics Polaris model.
BUT many other headsets do work with Mitel telephones. Since they are not "supported" by Mitel, you should contact the headset manufacturer for configuration guidance. Some have dip switches, or dials that need to be in certain positions to work with certain telephone models. This can be different from one phone to another.
Plantronics web site and their support people should be able to guide you to configuring this headset properly for each model phone.
How is the headset and handset connected? It sounds like the CS60 is connected to the handset port of the phone and the handset is connected to the CS60. When you go off hook with the handset, it sends the signal to the CS60 and depending on the switch on the CS60, it will send the signal to either the handset or the headset.
OR
The CS60 is connected to the handset port and the handset is connected to the headset port. To make the headset port work, you must have the CS60 connected to the headset port and the handset connected to the handset port. Set the phone to Headset mode.
1helpful
I have a CS60 Handset doesnt work when the headset is connected
First setup the headset as follows:
  • Locate the 2 ports on the bottom of the CS60 charging base. One has an icon of a "full telephone" and the other has an icon of a "hand receiver."
  • Unplug the hand receiver from the base of your existing telephone and plug it into the "hand receiver" port on the CS60 base unit.
  • Then take the short cable that came with the CS60 and plug it into the "full telephone" port on the base of the CS60.
  • Plug the other end of the short cord into the hand receiver port of your telephone (where the hand receiver just was).
  • Make sure the AC Power is plugged into the wall, and then you can adjust the configuration settings.
To be able to hear or speak through the handset, either place the headset back into its charging cradle or press the call control button on the side of the headset. The talk indicator light on the base should go off and no sound will come through the headset.
Note: Make sure that the cables are connected correctly and the handset cable is connected to the base of the CS60 base.
1helpful
Need to extend the range using the CS60
There is no way to extend the range on these as they are not GAP compatible so will not work with repeaters. However the you may want to look into the Plantronics C65 as this is GAP compatible and you actually pair it up to a GAP comapatible cordless phone which should allow it to be used with repeaters. I have successfuly hooked one up to a Kirk system some years ago and also with a Siemens C450 which worked fine. Most cordless devices generally will not cover 200m unless you go to industrial high power cordless phones like the Engenius.
1helpful
Plantronics Problem with my headset
Setup the Plantronics CS60 wireless headset as follows:
To be able to hear or speak through the headset, press the call control button on the side of the headset. The talk indicator light on the base should go on and the green light on the side of the headset should be blinking.
3helpful
Connecting headset to phone
Top Maax Home Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Maax Home Expert? Answer questions, earn points and help others
