The voltage should be good. It is possible the Infra-red emitter tube might be at fault.
The night vision can work under a full moon, so test the vision part to make sure it is working correctly. If you have an infra red/IR remote control for your TB set, you can test the might vision using that remote to see if the night vision is working.
You can use a second working unit to see if the illuminator is actually working. The illumination is not visible light without assistance.
Thank you for your advice, I tried to look at night than anything to see. my TZS-2 is completely dark when turned on, only a small glow around the phosphor plate. Is there any way to measure the lamp in the device? Defective other component? What is the operating current for the lamp? 725V or 80V?? I have something to measure and write off?
The open circuit 725 volts is good, your meter is loading the circuit some. The
The difference you see is normal. The 80 volts with tube in circuit is also good.
The imaing tube has a limited life, on average about 200 hours.
Check for oxide corrosion on the conductors, copper oxide can become a diode type resistance. Especially to chassis or body of device. It can be enough to disrupt the circuit.
