One of our staff was cleaning the unit and poured the water out by tipping it upside down as the manufacturer recommends. Since then unit cannot be turned on without popping the GFI on the outlet. We let it sit for 2-3 days and then tried it again but it still pops the GFI. I would like to take the top off to dry it out but I can't find any screws other than the two under the water reservoir cover. Any help with taking this apart would be greatly appreciated.
You need to call a licensed electrician, any attempt to fix this by an untrained person is dangerous. I will provide no advice on the matter.You need to call a licensed electrician, any attempt to fix this by an untrained person is dangerous. I will provide no advice on the matter.
Hi Lee... I took out the two screws but the cover still will not come off. I didn't know if maybe there are clips that are also holding it on. Thanks for the reply.Hi Lee... I took out the two screws but the cover still will not come off. I didn't know if maybe there are clips that are also holding it on. Thanks for the reply.
You can't post conmments that contain an email address.
Re: Repairing Bunn BTX-B - Popping the GFI Breaker
The screws are under the flip lid where you ad water. sounds like your heating element is shorted most common problem with the bunn not hard to replace call bunn for replacement or order on line. hope this helps you. .lee
unplug machine and turn upside down and pour out coffee and water mix (if water was in reservoir) If necessary turn over and fill will water and repeat.
To clean your brewer, pour in 1 qt of white vinegar into the top, place the carafe on the base and close the lid. Allow the vinegar to sit in the machine for 2 hours. After 2 hours, turn off the machine and let it cool. Then remove the sprayhead and insert the metal spring(deliming tool) into the hole where the sprayhead was and twist it 5-6 times. Then you will flush out the machine by pouring 8-10 carafes of water through the machine.
There is an electrical problem with the brewer. If you will please get the model and date code located on the bottom of the machine, and call customer service, we will be happy to assist you with this. The machine has a 3 year warranty and if the machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
The easiest way to empty these brewers is to turn them upside down over the sink. Turn it on it's side, always keeping the fill hole down toward the sink, and keep on going until you have the unit completely upside down. If there is a push switch under the lid to stop water from going into the pot until the lid is closed, you will have to keep this pushed in until the unit is empty
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix. 1) Unplug the NHB 2) Remove accessories like the pot and basket 3) Bring NHB over to the sink 4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up. 5) Place the top cover and flow stopper aside. 6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out. 7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir. 8) Return the NHB to the upright position in the sink. 9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse. 10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions. 11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir. 12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely. 13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose. 14) Tip the unit as in step 7 to drain the tank water out. 15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole. 16) Repeat steps 13 and 14 once. 17) Repeat steps 11 through 14 three times. 18) Clean the pour reservoir cover, swing lid and flow stopper. 19) Put the flow stopper back in place. 20) Attach the top cover. 21) Clean the exterior of the NHB. 22) With the boil and warmer switches off, plug the NHB into the electrical outlet. 23) Turn the boil and warmer plate switches on. 24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute. 25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water. 26) Allow water to drain from brew spout until it stops draining. 27) Empty pot. 28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot. 29) Clean brew spout diffuser and replace back in the brew hat. 30) Clean the pot, pot lid and brew basket. 31) Wait ten minutes for the water in the tank to boil. 32) Brew your coffee as you normally would. The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
1) Unplug the NHB
27) Empty pot.
