Vtech Digital Cordless Telephone VT-2568 Logo
Jerry Posted on Jan 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone to answer calls
Phone will not recoard messages that come in
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vtech Master 102,366 Answers
  • Posted on Jan 31, 2012
Vtech Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10433748
Points
622693
Apparently your system is set in "Announce" mode instead of "Answer" mode. To switch modes, see the instructions on page 26 of the manual.
How can you skip tracing?
You can skip tracing via texts or phone calls:
Phone calls: Local phone calls are answered more so prefer a mobile phone that allows you set up local phone numbers whenever desired.
Custom greeting messages: When a person doesn't answer the phone call, you are instructed to leave a voice message. Now, when the other person calls you back and your greeting message differs from the one that you had left in the voice message, he would straight away hang up your call.
You can also use tools for skip tracing to do the needful task!
How can i limit the number of rings before the answering machine kicks in on my panasonic 6.0 phone
Answering system settings Number of rings before the unit answers calls You can change the number of times the phone rings "Ring count" before the unit answers calls. You can select 2 to 7 rings, or "Toll saver". The default setting is "4". "Toll saver": The unit's answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 4th ring when there are no new messages. If you call your phone from outside to listen to new messages , you will know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call. 1 {MENU} i {#}{2}{1}{1} 2 {V}/{^}: Select the desired setting. i {Save} i {OFF}
1helpful
Voicemail button redirected to phone line
If, perhaps you mean "it rings another one of our..." Phone Extensions, then just press the illuminated red message button, go to the ringing phone (the extension number will appear on your phone if you have a display phone) and answer the call by lifting the phone off-hook, then hang it up. Now the message button on your phone will work normally. What happened was that the user of the phone that was ringing when you pressed the button had inadvertently left you a "message waiting" after they called your phone on the intercom. By pressing the message button on your phone, you returned their call, and by answering the return call, you cleared the message waiting indication on your phone. There can be more than one message waiting, so if the light is still on after you clear the first call, using the procedure above, do it again and again until each call is returned, answered and cleared.
Panasonic number ring
Number of rings before the unit answers a call.You can change the number of times the phone rings "Ring count"before the unit answers calls. You can select 2 to 7 rings, or "Toll saver".The default setting is "4 rings"."Toll saver": The unit's answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 5th ring when there are no new messages. If you call your phone from outside to listen to new messages (page 34), you know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
2answers
I have a XS1455 answering m/c. Have a problem
Messagebank provides a personal answering service if your phone line is busy or you can't get to the phone. You don't need extra equipment like answering machines, and you also get greater flexibility on call waiting- if you don't want to interrupt your call, let messagebank take your message. Let me know if this answers your question. Master FixYa: [email protected]
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
2helpful
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Remote access, panasonic cordless phone and answering machine
I phoned in from another phone and retrieved my messages. The problem was not with the answering machine but with the phone and calling card I had been using. Don't use a hotel switch board nor calling card, too many intermediate parties for the 2 digit code to work with.
Samsung Mobile phone_Camera problem
my cellphone keep going into pause temp and will not hold a charge
6helpful
Phose set up
Here is the link for your manual if you still need it. http://www.uniden.com/pdf/EXAI398iom.pdf
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
