Mom bought a laptop, we got that all ready for her and all of asudden our Compaq will not connect to internet. All wireless connections are ok and available, checked ISP, etc. Other computer works fine. It even shows that the wireless internet is available, but won't connect. help
Are you at home or Starbuck? location matters.
so, the compaq must be setup correctly.
your router broadcasts the SSID name seen by you on all devices, see that on the Compaq (y/n)
then you must pick wep. or wpa, or wpa2 encyption mode.
as set in your router, we cant see inside you router only you can
then set the passphrase to what you router wants.
is this XP, windows
does the wifi chip look ok in device manager?
Is XP infected.? with malware as all are now.
never post about computers lacking what operating system you have, or answers will be wrong, even all answers.
SOURCE: laptop compaq armarda notebook can not get connected to internet
TRY UPGRADING INTERNET EXPLORER
SOURCE: wifi problem in compaq presario c762nr notebook
Your network profile is damage create a new one, once the profile get corrupted it will never allow to connect to any outside networks due to security measure.
Hothawk
SOURCE: Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
SOURCE: compaq presario m2000 blue wireless light doesn't
This problem is vary common in many types of laptops , you can have many solutions :
