Our Whirlpool ADP 6515 has a delay button. When the button is pressed and activated for a 3 hour, 6 hour or 9 hour delay, if we change our minds and want to wash immediately, we cannot disable the button!! How can we deactivate the delay setting to wash immediately? We have pushed the delay button over and over to turn it off but it will remain on the 9 hour delay setting. We are very frustrated. Please help.
Many owners of the Bosch dishwashers perceive h01 (h: 01) or h02 (h: 02) and other signs as an error. But in fact, this is not an error, and you accidentally got into the start-up timer menu (delayed start of washing dishes). In this case, h01 means that washing dishes will start exactly in 1 hour; if the display shows h02, then washing process will begin exactly in 2 hours. As a rule, in most models of dishwashers from Bosch, a delayed start can be set in the range from 1 to 24 hours.
Timer programming
You can delay the start of the program in 1-hour steps up to 24 hours.
Close the door.
Switch on ON/OFF switch [1].
Press button [4] + until the digital display [9] jumps to h:01
Press [4] + or - button until the displayed time corresponds with your requirements.
Press START button [6], timer programming is activated.
To delete timer programming, press the [4] + or - button until h:00 is indicated on the digital display [9].
You can change your program selection at any time until the program starts.
You have activated the delayed start function. Please read following instruction from user manual.
8. Delayed Start button
Allows the start of the programme to be delayed by a minimum of 1 hour, up to 9 hours. How to set the delayed start When the button is pressed, the number appears in the display (4). Press the button again to select the number of hours by which you wish to delay the programme start, up to a maximum of 9. E.g.: if you have selected number , the wash programme will start in 2 hours' time. To cancel the delayed start set, press the button until the number appears. Close the dishwasher door to start the countdown: a long audible signal (about one second) informs you that the function is active. If you open the door again you will see, in the display (4), how long there is to go (in hours) before the programme starts. A flashing dot in the digital display means that the delayed start function has been activated. Opening the door has no effect on a countdown which has already been started. If, during the countdown, you wish to see the programme number selected in the display, press the Programme Selector button (5). If, after having started the countdown by closing the dishwasher door, you wish to cancel the delayed start, press button (9) (Cancel) for about 2 seconds until the short «instruction accepted «signal is heard».
In fact, this is not an error, and you accidentally got into the start-up timer menu (delayed start of washing dishes). In this case, h01 means that washing dishes will start exactly in 1 hour; if the display shows h02, then the washing process will begin exactly in 2 hours
Timer programming
Close the door.
Delayed Watering
You can delay the first watering cycle of each watering zone by up to 12 hours by using the small button at the bottom middle of each zone area. Press the delay button 1 time for each hour you wish to delay the first start time. The "Low Battery" light will illuminate when you press the button. The maximum delay is 12 hours.
For example, if you are programming at 4:00 in the afternoon and you want your timer to water every 12 hours, but you want the first watering of the day to start at 6:00 a.m., press the Delay button two times. Without the delay, the first cycle would have occurred 12 hours after the timer is programmed (4:00 a.m.). The delay feature changes that to 6:00 a.m. The timer will then water every 12 hours after that.
How to set the time:
1. Plug in the unit. Wait until the hour on the LCD starts blinking 2. Press the CLOCK button to set the correct hour 3. Press the SET button to switch to minutes 4. Press the CLOCK button to set minutes 5. Press the SET button to accept the time
***there is no AM icon, only PM***
How to program delay brewing:
1. Press and hold SET until the hour begins to blink 2. Press PROGRAM until you see the tiny bell icon on the bottom of the screen 3. Press CLOCK until you get to the hour you want to start brewing 4. Press SET to switch to minutes 5. Press CLOCK to get to the minutes you want to start brewing 6. Press SET to finalize
Press PROGRAM to activate. When the little bell is flashing, the coffee
pot is set to go on at the desired time. While the coffee pot is on or
in warming mode, there are vertical lines on the top of the LCD screen
that shows you it is on. If you press the ON/OFF button, you can turn
it off before the two hour keep warm cycle is complete.
