When turning the receiver on i get a short welcome message, the muting lights starts flashing, i hear a click and it goes on protect. Everything stops then.
Double check the speakers connections and ensure wires are not interacting with each others according to the channels employed.
Hello
Check the putput wirings to speakers. If any of them has short circuit, the set will go to protection mode. You can understand it well, as it did worked fine at the repair shope. The set has no fault at all, but the wirings, connects to it have.
Just power ON the set at your home, without connection any output or input to it. See, it will not show any protection mode display. Switch it OFF. Connect the output to speakers, one at a time, and switch ON the set. Just do it for all other speakers. This way, you can find out, which speaker line causes the set to go to protection mode. Fine out the reason.
Never connect any input to the system, until works fine with out showing any protection display.
I helped you somewhat fine, I assumes.
Ok.
I've disconnecting everything with the receiver unplugged. I then plugged in the receiver and switched it on. As above, the welcome message roles across the display screen and then the reciever goes "click" and the "protect" message comes on. I push the reset button on the back which turns the receiver off. I switch it back on and I get the same response. "Welcome" then "Protect"
We did do exactly what you said and it worked for a while and the next morning it went back to protect. And so on and so on. Works and after shutting it down after some time it goes back to protect mode. At the moment I have it on now for 8 hours and i will leave it on overnight and see what happens tomorrow morning. Thanks
