Question about Janome Memory Craft 9500 Computerized Sewing Machine
Broken Carriage? I accidentally left something behind my machine, not leaving enough room for the carriage arm for embroidery. Now the machine makes a funny noise and the carriage will not move properly. It will move from side to side, but not back and forth. Is there a way to fix this without sending it to the repair shop? Taking it to the shop will probably cost a minimum of $100-$150.
  • Janome Master
  • 2,486 Answers
I do not think this is a DIY repair. That said, it seems likely gearing has been damaged. Without a workshop manual, even if you found the gear, you do not know the identification number for it. I see no authentic download of the workshop manual on the web for this Memory 9500.
I only find the Instruction manual available on the web (freely available at the Janome site). Even if you find a Janome technician on an answer site, that is not going to get you disassembling the machine, replacing the part, reassembling it, and adjusting it.
Check Janome support and see what they offer: tech advice, workshop manual for sale, and/or parts. You are likely to conclude you need to find someone at a service center.
Here are some links:
http://janome.com/en/support
http://janome.com/siteassets/support/manuals/retired/embroidery/inst-book-mc9500.pdf
Instruction Manual Janome and Newhome 9500 (hardcopy, some parts)
http://www.janomeservicevideos.com/wordpress/wp-content/uploads/2015/02/Error-Codes.pdf There is only one reference to the 9500 on the page.
Posted on Sep 03, 2017
2 Suggested Answers
SOURCE:
SOURCE: strange noise from the lever that connects the hoop to carriage
Is this where the belt would be also, because my arm bumped the wall because it did not have enough clearance and it jumps and clicks when returning to home.
withtlc@mchsi.com debbie
Posted on Jun 21, 2010
Where is the lever to return the carriage arm back in position on my embroidery 300E
Go to embroidery screen. Press start/ stop button. Arm should automatically return
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_affa8ba20bcbf6c9
May 30, 2018 | Sewing Machines
The carriage on my babylock EMP6 is clicking and will not align.
Sounds like your carriage gears are slipping as though there is something blocking the carriage from moving. Could be the carriage is not seating properly.
Jan 12, 2014 | Baby Lock Sewing Machines
Embroidery unit
This can happen, click back to tools option check whether hoops selection is correct. If this is not the problem, off your machine then put on again. If message remain pull out the embroidery carriage & push in again. Hope it can work.
In jam situation, just exit from your embroidery option, fix the jam by moving the embroidery carriage, work on a different design and see if it work. Sometime a design may not work fully.
Sep 29, 2013 | Singer CE-100 Futura Computerized Sewing...
My Bernina deco 340 embroidery carriage is out of line
sounds like something isn't installed correctly or is broken.
Sep 07, 2012 | Bernina Sewing Machines
Carriage of my futura 200 is stuck
Turn off the machine, remove the Hoop from the embroidery arm, then turn it back on. You'll notice some of the hoops have an extra piece of metal that the machine identifies it with. Mine just didn't like the hoop I had on.
Jul 07, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura ce-200 "parked" in wrong position.
I think you might have damaged the embroidary arm.
Contact these people for some advice.
Gezina sewing machine
(012) 335 0636
Feb 27, 2009 | Singer CE-200 Quantum Futura Computerized...
Embroidery arm
Turn off the machine, remove the carriage, check that nothing is hitting against the arm and try again.
Sewman7
May 18, 2008 | Brother SE-270D Computerized Sewing...
The carriage of the embroidery unit is not move automatically to the embroidering standby position.
Is the need in upright position ?
or have you fitted the embroidery hoop correctly.
If all else fails switch off and start up again - should then automatically go to correct position.
May 16, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer Quantum Futura CE-200 Problem
My machine did the same thing. I had several frustrated nights ans then it just started to work. Some suggestions that I had was that there may be dust where the units connect. Not sure what I did, but it worked.
Dec 27, 2007 | Singer CE-200 Quantum Futura Computerized...
Carriage not returning
Dear Netter - I too have a CE-200 Quantum Futura Sewing/Embroidery Machine. I have run into similar problems. I have tried the various things suggested: remove hoop, turn off machine, turn on machine, replace hoop. However, often the carriage does not return to the initial location (carriage all the way to the left, mounting plate all the way to the bottom, closest to the user). I have found that with the gradual application of force, I can pull the mounting plate all the way to the bottom of the carriage. I turn off the machine before I do this. I have not tried to move the carriage to the right or left; I have not had to. Sometimes when I turn the machine on, it beeps steadily (more than the usual 3 or so complaints). But when I turn it off and on again, eventually it is ready to continue embroidery. By doing this, I may be causing damage to the machine or making the warranty void. If you do it, you may face the same problems. Or it may make your machine into an expensive paperweight. I can't offer you a complete solution for your problem, but I hope this helps.
Nov 09, 2006 | Singer CE-200 Quantum Futura Computerized...
Janome Memory Craft 9500 Computerized Sewing Machine Logo
98 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
