Sir if i plug my compaq mv520 into AC outlet and I turn it ON the power led flashing orange to green color and vice versa and I turn it OFF back then I connect into The system Unit and I turn ON the Systen Unit as well as the monitor and I found out that the power led stop flashing but from green turn into orange which is stand By Mode.Sir My System Unit have no problem because I try it into other monitor it works fine So the problem is in my monitor.Sir it is posible that the problem is in the Power Supply of the monitor? Help me Find out sir,Thanks in advance!!!
It could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
SOURCE: Sir help Me with my Compaq MV520 monitor the power led flashing orange to green and vice versa
Hi..there! Sir Neil:
You're right... Your backlight inverter are busted. Need to replaced a new one or repaired it.
bad
