I have a new take up spring and need instuctions on to install it
Take up spring is very important. theres a screw on the right side of the post located on machine body. loosen and remove entire tension device. don't lose the tension pin in the center. now look at the tension post and you will see a small screw that when loosened will allow u acess to the take up spring. study the way the spring in place.the end of the take up spring fits in a slot on the post. remove old spring and slide in new one making sure the free end of the spring goes in the slot on post, put the other piece back on and twist till u have med. tension on the spring them tighten the screw, put tension pin back in center of post and slide device back in machine. take up part should be arounf 10 oclock. tighten screw to hold tension device. u can change the spring tension by putting a screwdriver in the slot where the tension screw is located. turn right for more tesion. sorry but this is a hard repair to put in writing because its simple but requires ome experience.
Contact a juki dealer to see if they can give instructions
SOURCE: problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
SOURCE: threading juki DDL-227 machine
There is a free download threading diagram for the DDL-227 here:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
SOURCE: i need instruction and parts manual for juki
JUKI HOME SEWING DIVISION
8500 NW 17 th Street
Miami, FL 33126
Phone: (305) 594-0059
SOURCE: Hi I have 5 Juki DDL-8700-7 machines and I need to
So many machines you would be best at aution as one complete lot.
