Model 3050A I have a paperjam with no instructions on how to fix. Please help. I have an impending deadline. Thanks.
SOURCE: I have hp deskjet 2300d showing that their is a
There is a line of sensors along the paper path, if any of these are obscured by even the smallest scrap of paper you will get the messasge, re check the paper path again it only needs a scrap of paper, if you can spot any of the sensors give them a blow with some compressed air (paper dust build up), last but worth a try unplug for 2 minutes to allow residual power to drain and then try power up and see if the message has cleared
SOURCE: HP Deskjet 3745 says "out of paper" even if there
Relace the bend papers and delete the due print in printer IQ.Restart the printer and check if problem did not solve then try it----->Remove the power plug and then--->
and restart the pc plug in the printer.Check the status if problem persist uninstall the driver and install the driver again.If you give A4 paper,choose the paper A4 in printer setting.I hope this will be solved.
SOURCE: Hp Deskjet D2360 printer says
Go to printer icon >>>right click go to properties >>>then go to tools >>> click on the configuration to set repair your printer...
If the problem still persist call a technician to clean the nozzle of the printer
