Akai LCT2060 Television Logo
Posted on Oct 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Akai LCT2060 I turn the power on, the blue light stays lit, but the screen lights up for 3 seconds and then the screen goes black. Is it the LCD power supply going into "Protect mode"?. Does it need to be replaced, where can I get one and can I do it myself?
Anonymous
Level 2:
  • Expert 286 Answers
  • Posted on Nov 04, 2008
Anonymous
Expert
Level 2:
Answers
286
Questions
Helped
253616
Points
565
This is a mean problem, and I feel for anyone who has it.
This can be caused by a bad power board, a bad main board or a lcd LCD panel.
An authorized repair shop would be able to substitute the main and power boards to find the source of the fault, but you don't have that luxury.
Unless you want to risk paying for an expensive part you don't need, I would suggest you take it to an Akai repair shop.
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
I recently bought a Hp Lcd w1907 Monitor off craigslist, the screen worked fine for about an hour then went black, button stays blue. Now every time I power on the monitor it stays lit for 3 seconds...
hi the cause is screen back light not working properly. you need to remove the back cover of the monitor to access the internal part of the monitor. then look for the connector of the cold cathode fluorescent tube back light going to the power inverter board of the back light you will noticed a dry joints which cause a loose connection that is why you hear a sound that cause of spark. you need to re soldered the connector or replaced if totally burned.
My akai lcd 32.5" tv will not stay on and all it does is flash the blue screen with akai then turns right back off and i was thinking power suply might be bad. what could it be?
You could be right it sound like the power suply, has it got a AC adaptor power suply,bit like a laptop charger? goes from mains to a black box then from box to the TV?
does it stay on at all?
Akia lct2070 screen went black and will now shut its self off
You may need new inverters, CCFL's, or your power supply is not [providing regulated 24 volts...
Inverters
CCFL assembly
power supply
We have these Akai boards in stock if you need them.....
My akai lct 2070 screen has two issues one is that about a month ago the screen went black only viewable with a light next to it and now when the tv is turned on it stays on for about 30 seconds before it...
Inverter
power suply
CCFL assembly
One of these boards are causing this problem, we have them in stock if you need them. the tv is programmed to shut down if all circuits are not functioning properly.
Monitor in sleep mode
I think it maybe time to buy a new monitor
Screen goes black after 2 seconds
Akai LCT3201AD 32 in. LCD
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
2answers
AKAI 20 INCH lcd MODEL #LCT2060
This is an indication that one of the components in the screen control sections has a thermal instability problem. This canusually be found using a product called cool mist which is a component cooling spray. This lowers the compenent temperature and allows you to see which component has the problem. Also you may want to if you are able try to use a voltmenter and a schematic to trace the problem down once you know which component is giving you the problem.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
