No pilot light, uses piezoelectric to light gas, so you could use a match to light the burner...Proceed at your own risk, DO NOT DO THIS IF YOU DON'T KNOW WHAT YOU ARE DOING
Check next to the burner that is not working for any buildup
The part that produces the spark is white with a short piece of metal sticking out the top,,,the spark arcs over to the burning igniting the gas
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap. If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
In the old days stoves were lit with a match. If this does not work for you it would be due to the stove's lines remaining "airlogged" after the move. The oven purged and ignited more easily because it has a much larger orifice, so the air bled more quickly. I expect if you were to leave one burner turned on long enough for the air to bleed out you will find it to ignite normally. Do not leave the stove to bleed unattended, and if you encounter a strong smell of the gas, turn off the burner, and ventilate the room as needed. The smell of gas would indicate that gas is present, it may be possible that a lead came disconnected from the ignition module in the back of the stove. Again if this is the case, the ol' match will light the burner. Be Careful!
