Kenmore Side by Side Refrigerator Logo
Anonymous Posted on Jan 30, 2012
Water dispenser not working
Model 596 52673200. The water flow was becoming less and less now no water flows at all. We can hear the motor, but no water flows. We checked the plastic water resevoir at the back of the fridge. It looks fine. We can see water in it.
Anonymous
Level 3:
President:
  • Master 2,187 Answers
  • Posted on Jan 30, 2012
Anonymous
Master
Level 3:
President:
Answers
2187
Questions
0
Helped
559968
Points
6379
Check the water lines for any debris found inside. You may want to check the filter. Other than that it may be a weak motor.
2answers
Water dispenser works ice maker works but no ice through dispenser
If your refrigerator's ice maker is working, but no ice is dispensing through the dispenser, there are a few possible causes and troubleshooting steps you can try:
  1. Check the ice chute: Make sure the ice chute is clear of any ice obstructions. Sometimes, ice can get stuck in the chute, blocking the flow of ice to the dispenser. Use a plastic utensil or a straw to clear any ice buildup or debris in the chute.
  2. Inspect the dispenser mechanism: Open the dispenser area and check if any part of the mechanism is obstructed or damaged. Look for any ice blockages or misaligned parts that may be preventing ice from being dispensed properly. Clean or repair any issues you identify.
  3. Verify the dispenser solenoid: The ice dispenser is usually operated by a solenoid that controls the release of ice from the ice maker. Ensure the solenoid is functioning correctly by listening for a clicking sound when you press the ice dispenser paddle. If you don't hear a click, the solenoid may be faulty and require replacement.
  4. Check the dispenser motor: The dispenser motor is responsible for activating the auger that pushes ice through the chute. If the motor is not functioning properly, it may need to be replaced. Test the motor by activating the ice dispenser and listening for any humming or buzzing sounds. If you hear the sound but the auger is not turning, the motor may be faulty.
  5. Inspect the ice bucket: Ensure that the ice bucket is properly installed and seated in the correct position. Sometimes, if the bucket is not aligned correctly, it can prevent ice from flowing through the dispenser. Remove the ice bucket and reposition it securely.
  6. Check the water supply: Make sure the refrigerator has a steady water supply. If the water supply is interrupted or the water filter is clogged, it can affect the ice production and dispenser functionality. Check the water line and replace the water filter if necessary
I have LG refrigerator LSC27950, there is ice in the icemaker& when I press the lever I hear humming noise for water and clicking noise for ice, but no ice or water are dispensing?
The error code dH on your LG refrigerator is indicating a water supply problem. This could be caused by a few different issues:
  1. Clogged or frozen water line: The water line supplying the icemaker and water dispenser may be clogged or frozen. This can prevent water from flowing to the icemaker and dispenser. Check the water line and make sure that it is not clogged or frozen.
  2. Water inlet valve: The water inlet valve that supplies water to the ice maker and dispenser may be faulty or clogged. This can prevent water from flowing to the icemaker and dispenser. You can check the water inlet valve and make sure it is functioning properly or if it is clogged.
  3. Water filter: A clogged water filter can prevent water from flowing to the icemaker and dispenser. If your refrigerator has a water filter, make sure that it is not clogged and has been replaced recently.
  4. Water pressure: If the water pressure is too low, it can prevent water from flowing to the icemaker and dispenser. Make sure that the water pressure in your refrigerator is adequate.
You should first try to check the water line, water inlet valve, water filter, and water pressure. If none of these solutions work, please contact a professional technician or LG customer service to diagnose and fix the problem.
Our Bravos XL MVWB725BW0 started overflowing the fabric softener dispenser, because the water flow is way too high. The same thing, to a lesser degree, happens on the bleach dispenser not as much water,...
It sounds like there could be a few potential causes for the excessive water flow in your Bravos XL MVWB725BW0. Here are some steps you can take to troubleshoot the problem:
  1. Clean the dispensers: Sometimes residue or buildup can cause blockages that affect water flow. Try cleaning the dispensers thoroughly with warm water and a mild detergent, then rinse thoroughly.
  2. Check the water pressure: If the water pressure in your home is too high, it can cause water to flow too quickly through the dispensers. You can use a water pressure gauge to check the pressure and adjust it if necessary.
  3. Check the water inlet valve: The water inlet valve is responsible for controlling the flow of water into the washing machine. If it is faulty or clogged, it could cause excessive water flow. You can check the valve for any signs of damage or wear, and replace it if necessary.
  4. Check the dispenser hoses: The hoses that connect the dispensers to the washing machine can become clogged or damaged, causing water to flow too quickly or slowly. Check the hoses for any signs of damage or blockages, and replace them if necessary.
  5. Check the control board: In rare cases, a faulty control board can cause water to flow too quickly through the dispensers. If you have ruled out all other potential causes, you may need to replace the control board.
If you are not comfortable performing these steps yourself, you may want to consider contacting a professional appliance repair technician to diagnose and fix the problem.
1helpful
Replaced water dispenser still not moving or getting water
Water dispenser doesn't work
  1. Dispenser control board
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
  1. Water tube in door is frozen
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
LG LRSC21934 ice maker/water dispenser doesn't work
If your house water supply to the refrigerator is poor it is most likely the cause of the water dispenser and ice maker not working. If you hear the water valve humming when the water dispenser is depressed and no water is dispensed it is most likely poor or restricted water flow to the refrigerator.
If you live in an older home the water supply shutoff valve to the refrigerator is usually in the basement or under the kitchen sink. Many shutoff valves are called a saddle valve and the valve is secured onto a cold water pipe and as the valve is turned clockwise a pin punctures the water pipe allowing water to flow. Saddle valves often become clogged with minerals and can completely block water flow to the refrigerator,. If the valve is corroded on the outside it should be replaced. Ice maker installation kits are available at most hardware stores. Copper water line kits are preferred. Cost is under $25.00. If the Saddle valve is in good shape they can be taken apart and cleaned. Be sure to shut off the main house water and drain pipes before attempting to clean.
Newer homes may have a water box in the wall behind the refrigerator. Sometimes these can become clogged with mineral deposits as well.
Hope this helps.
Mike
1helpful
2answers
My water dispenser flows very slowly. The unit is
Check for clogged output valve. Second the filter candles require an annual change as they also get clogged from filtering water.
Thanks for using fixya
proton
Water not dispensing/flow is not fast
Sound like time for a new filter. When was the last time it was changed? If less than a year or two, it's not the problem. If more, it's likely the filter is clogged reducing the pressure flow of water.
Ge monogram water line
the water dispenser does not dispense water, although i can hear the motor running, but water is reaching the ice maker.
any tips?
You may have a clogged water line or filter something blocking the flow of the water or you may have to replace the filter or a water line – it may have a defective sending unit / pump and it would be wise to check it out with a regular service tech and to also check your owner’s manual for troubleshooting.
3answers
2helpful
Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
