Vtech Cordless 6041 Phone Logo
Posted on Oct 19, 2008
Phone doesn't ring on incoming calls
Both ringers are on (base + handset), but sometimes & after phone has been inactive for a while, when receiving calls both base & handset don't ring and the answering machine doesn't pick up.
  • 2 more comments
  • javi_guevara Oct 27, 2008
    I have the 6032, and it's not ringing, I think it's broken because in the manual doesn't specify this problem. The warning possible interference it's ridiciulous, everyone have at least one electronic device in our homes!!!.
  • Anonymous Nov 18, 2008
  • bg131 Jan 12, 2009
    We just bought this phone and have the exact problem. We have been through the manual, set both the handsets and base. Nothing will ring and the answering machine will not pick up. Incoming calls show up on missed calls with Caller ID. Help?
  • Anonymous Mar 23, 2014
    I have had two vetch 6041 handsets over three years without any issues. One day I came home and one of the handset was not working. Getting "No Line". Can't receive any phone calls. Phone don't ring.
    I've interchanged the handset to the other base, still the same issue with the same phone. I interchanged the battery, still same issue with the same phone. I've unplugged all phones, still same result with the same phone.
Timothy Johnsen
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 01, 2015
Timothy Johnsen
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1036
Points
I just fixed my phone. I was using a MagicJack (VoIP) and the power supply to the unit wasn't putting enough power out. The solution was to buy a new power supply for the MagicJack. This might help anyone who is using this phone with VoIP (Voice over IP).
I'll also mention that my father was having the same problem and he was hooking his phone directly into the house wiring. It tuned out he had too many phones connected. He disconnected all but the cordless phone and now it works fine.
Hope these suggestions help.
Anonymous
Level 1:
  • Posted on Oct 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1036
Points
7
I cannot fix the number of times for the ringer on my vetch phoneset
Why does my Panasonic KX-TGM420 go straight to voice mail?
Voicemail is a service of your telephone company. If your calls are going to voicemail, check the settings following the directions for the service. If the answering system is getting the calls, then check if the KX-TGM420 handset(s) and base are set to a ringer volume of 0. You can change this from either the base or a handset by pressing the + button while the phone is ringing. Otherwise, when the phone system is in standby (no calls in or out), press # 1 6 0 on a handset or * # 1 6 0 on the base. Then set the ringer volume on the handset (0-6) or base (0-10). This is the equivalent of pressing menu and navigating through the menu (Menu > Settings > Ringer Adjustment > Ringer Volume (Incoming)). You can also turn off the ringer by pressing and holding 0 on the handset and Ringer Off on the base. See pages 33 and 44 of the manual, link below.
I hope this helps. The manual is available here: https://help.panasonic.ca/viewing/ALL/KX-TGM420/OI/TGM420_PNQX7794YA/TGM420_PNQX7794YA.pdf .
I have a KXTGE440 cordess phone it has a dial tone and I can dial out ok but incoming calls don't ring?
Do you have rechargeable NI MH rechargeable batteries?
Is Call Blocking on?
Is answering on with two rings?
Have you tired to adjust the volume of both the handset and base station?
Lift handset
Press + or - repeatedly to select the desired volume. - Repeatedly To turn the ringer off.
Base unit Press - or + repeatedly to select the desired volume. To turn the ringer off, press and hold - until the unit beeps
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
A180 just showing base and no response
Is the ringer turned off? Or is the volume on the ring tone set too low? Another possibility is that the phone isn't set to receive incoming calls - the Siemens phones I've owned allowed one to specify which handsets could handle incoming calls and outgoing calls on each line.
3helpful
Somehow the ringer got turned off. Can't figure
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
4helpful
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
GE 28851 base handset #1, will not save ringer tone or volumn I selected. Brand New.
As it turns out, the primary base handset did save the newer selected ring tone and volume level setting.
However, the base maintains its own ring tone and volume level setting from factory.
Therefore, the base will present its own settings along with the handset setting during an incoming call.
So, one has to lower the volume of the base (in non-talk mode). The base should display in window: LO.
Then, only the ring tone and volume level selected for handset will be presented during an incomiong call.
How did I do????
Ken
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
