Question about Cobra Radio Communications
High static level
My Cobra 29 has developed a very high noise interference (static) level. About 3X higher than it used to be. I can her someone fine if they are within 1/4 mi from me, and they can hear me if they are close to me.I have dual antennas (from factory [Freightliner]). The AM/FM radio also receives through these antennas. When I change the ANL/NB switch there is no difference in reception. The radio is about four years old.
  • Cobra Master
  • 3,289 Answers
Hi Gary,
It sounds like something may have loosened up. Given that this is installed in a truck it is probably subject to quite a bit of vibration. This could have broken a connection, etc. If this just started, consider what happened just before you noticed the change. Maybe the truck was serviced just before - consult with the mechanic to learn what he or she may have done to contribute to the problem. Maybe the antenna smacked a low hanging tree limb?
You could disconnect the antenna from the radio, and spin a metal protective cover over it to prevent signals from entering. If the static sounds are reduced, the interference is probably coming from the antenna system. If it remains, it is probably coming in on the power leads. With the ignition OFF, check for noise. If reduced or eliminated, it is related to the engine / electric fuel pump (if equipped), etc.
Check the PL-259 connector at the end of the coax cable. If the braid or center connection has failed, it should be repaired be removing the connector and preparing the cable to receive a new connector again.
Make sure the ground wires and braids are firmly connected at the radio connector end and at the antenna. Rust is a poor conductor and if present will interfere with transmit and receive. Clean it up, make your connections up tightly and then seal to prevent water from entering.
Check antennas for damage. Many antennas on trucks are fiberglass because they're tough. The wire wrapped around it however is soft copper. If the antenna has smacked tree limbs, overpasses, etc. they could have been damaged. The physical shock is transmitted down to the mount point - causing it to loosen up, etc. Repair and replace suspected damaged or loose parts. Make sure the rubberized weatherproof tip on Firestik type antennas are secure and in place.
Check the coax. Make sure the outer jacket is continuous and has not been compromised by being crushed between pinch points, chafed, etc. The jacket must not have splits or cracks that would allow water or oil in. Replace any damaged coax cable with identical type and lengths - this is especially important in a co-phased antenna arrangement as I understand is your current configuration.
A high SWR can also cause problems. Most manuals say 2.0:1 (two point zero to one)is maximum acceptable SWR or "match". I could go along with that provided that value is present of infrequently used channels - like 1 and 40. The channels used most often should have a very low SWR. 1.1:1 (one point one to one) to as much as 1.5:1 (one point five to one) is where I would expect to be on channel 20 (the mid point of the band). There will only be one place that the is the low point in the band. Transmitting further up or down the band from 20 will cause the SWR to increase. Eventually, you will exceed 2.0:1 and too much power will be reflected back into the radio - potentially causing a failure of the RF output final transistors. This is only increased if running a linear amplifier. Transmitting at a lower power make dealing with a higher SWR much easier than sending high power to a mismatched antenna system. Your set up may have a nice, wideband of acceptable match - 1.5:1 on ch1 and ch40 with 1.1:1 on ch20; or be very narrow banded like 3.0 (or more) :1 on ch1 and ch40 and 1.5:1 on ch20. It could even be "way out there" with 4.0:1 on ch1 and ch40 and 2.5:1 on ch20. if you've got a bad match happening, correct it ASAP!
Check you power source. The best place to grab power is directly from the battery. Yours may be there already, and even so, it may also have noise reduction components such as a choke input filter and or capacitor on the power leads. Look for these and other components inline and inspect for damage or contamination by oil, fuel, etc. Replace as needed. Check the power leads for any connected accessory, too.
That's about all I can think of.. good luck!
Posted on Feb 01, 2012
2 Suggested Answers
SOURCE:
  • 773 Answers
SOURCE: what exactly does the anl nb/anl button do on my
ANL stands for "Automatic Noise Limiter" and NB stands for "Noise Blanker".
The ANL gets rid of a lot of interference noise caused by mechanical noise from motors and other electronic components in a car.
It also gets rid of noise from other sources of interference.
The NB is for extreme cases of noise, but can slightly lessen your receive sensitivity.
Basically both functions help decrease interference noise.
Posted on Nov 24, 2010
A k 40 magnetic antenna has high swr and wire and everything looks fine
The K40 is known to fail after that many years in service when moisture gets into the coil it causes it to change it resonance freq. and hence the higher SWR. Buy and new antenna and enjoy 10 years is way to long for an antenna to last.
Apr 05, 2014 | K40 CB Antenna K-30
CB base Station picking up interfence with inverter
Inverters are full of diodes and diodes are extremly noisy devices. Also the filtering in CB radios is not the best as manufactures try to keep costs down to compete. Try unplugging the antenna from the radio and see if the noise stops. If it does not stop, then buy an inline filter to go in the supply to the radio and place it as close to the radio as possible. If the noise DOES STOP when the antenna is unplugged then it is coming in through the antenna and there is not much you can do but maybe buy a much higher quality radio with better filtering. You might try moving the antenna. Magnet mounts are not as good at blocking noise as high quality permanent mounts. Work to get your SWR as low as possible. Use high grade low loss coax from the antenna into the radio and use high quality connectors like the Amphenol brand. It takes time and effort to solve this type problem and some times nothing works.
Jul 17, 2012 | Cobra 29 LTD CB Radio
Cobra 29
Essentially what is done is replace the RF output transistor with one that can handle the 30 Watts output. Since you are not going to achieve it with higher B voltage, you have to modulate more current, and the bias voltages adjusted to accomodate the different characteristics of the new of the new final. Then the radio is checked to make sure the tank circuit is still in tune.
This is the basic outline of how to do it in a manner where you actually learn hands on, and apply what you should already know.
The alternate method is to install a linear amplifier. A 10 meter linear can usually work with only slight modifications.
BTW. the common search engines are worthless for finding radio mods. By design- they are oriented to a controlled marketplace.
Feb 22, 2012 | Cobra 29 LTD CB Radio
I have a cobra 29 ltd chrome and it making a lot of static noise while driving or idling. it transmits and recieves fine though
Hi, my name is John. Welcome to FixYa. Try running your power strait from the battery, that will bypass a lot of your noise. RED (+) ground (-) . Thanks for choosing FixYa....John
Nov 30, 2010 | Cobra 29 LTD CB Radio
What exactly does the anl nb/anl button do on my cobra 29 wx nw st
Nov 24, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I have had a Cobra 29 BT installed and my reception is nothing but loud static only when moving. It is a 2010 Freightliner and SWR is consistently high at about 3.0. Is this a coax or antenna problem?
Hi,my name is John. Welcome to FixYa. It could be both. Try running your unit direct from or to the battery, bi-passing all ignition noise. Make sure your antenna is getting a good ground, have your SWR checked at a near-by CB shack, or Radio Shack all for free. Thanks for choosing FixYa....John
Nov 16, 2010 | Cobra 29 LTD CB Radio
I get static so bad that I can't squelch it down enough to get rid of the noise. Traveling out on the highway it usually works ok. But when I enter a town the static gets badusually around power lines. How...
You could install a filter in the line between the antenna and the transciever. I reccommend a high-pass or band-pass filter set for the 27 MHz band to remove any interference at different frequencies. Also, some older TVs can cause interference to CB radios if they are close. If this doesn't work, the radio may be poorly sheilded or your area may have implemented the broadband power line initiative (BPL). This produces a strong buzz of noise that obliterates all weak to moderate radio signals between 2 and 80 MHz (CB being at 27 MHz).
May 21, 2010 | Cobra 19 DX IV CB Radio
Cobra 29 delta tune
For normal operation, set this control to the center position.
This feature has several uses and can help receiver operation.
If a received signal is slightly off frequency, the Delta-Tune control can be used to òfine-tuneó your receiver. Fine tuning is accomplished by listening for a more readable signal at the speaker or by noting the Smeter reading when the Delta-Tune control is operated. Another use of this control is eliminating adjacent interference (bleed over from other channels). If an exceptionally high level signal from an adjacent channel is creating interference on the channel being used, the Delta-Tune can be used to minimize or eliminate the interference. Rotate the control until you obtain minimum adjacent channel interference. NOTE: Delta-Tune is operable only in the receive mode.
It doesn't actually help receive any better, just can help kinda like a clairifier.
Dean Pitts
Rollin CBs
Mt. Vernon, TX
May 19, 2008 | Cobra 29 LTD CB Radio
Terrible static
What type of antennae are you using? If you are using an aluminum or stainless steel ant, I would suggest switching ti a fiberglass ant. It sounds like the metal ant is picking up the ambient voltage from the lines. If you are using a fiberglass already let me know, as you may have a more serious problem. Good Luck and I hope this helpsd L8R
Sep 17, 2007 | Cobra 29 LTD CB Radio
Radio Communications Logo
109 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
