Mu bosch dishwasher SHU33A, is stuck on drain cycle. I have tried to reset by turning power off, but when I turn power back on again it just drains. please help.
Tony
Cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Is the water pump motor running at the start of the program? you can hear it making a chugging noise if it is. If it's not running, the pump is probably jammed - this happened to mine a few weeks ago - there was a tiny piece of broken glass in it. There's a removable plastic cover inside the machine above the pump - take this off carefully, keeping the screws in the correct order - and you can see the pump impeller below. Remove any blockage, and reassemble. Try that!
I checked the tray and there is no sign of water. the anti flood switch is in the down position. My machine is still stock on cycle. is there a way to reset the machine?
Thanks
Bosch SHX43P15UC/64 Stuck in Initial Drain Cycle
