Error code 80010006 and ervery time it gets to 38% and it gives me that error code this was when i was tyying to do the 3.30 firmware update
Hello jenky2010
This error code relates to the PS3 having trouble accessing a file. This usually occurs when the PS3 is turned off while saving or accessing a file.
To rectify the problem, you'll have to into Safe Mode, and then select "Restore File System". If you're not sure how to enter Safe Mode, follow these instructions:
1. Turn off the PS3 by holding down the power button until the power light is red, then release.
2. Hold down the power button again. This should be shortly followed by a short beep, indicating that the PS3 is turning on.
3. Continue holding the power button, and after about 5 seconds you should hear a second beep.
4. Continue holding the power button, and after a further 5 seconds, you should hear a quick double beep. Release the power button. If you've successfully activated Safe Mode, you should receive the message" Connect a controller using a USB cable and then press the PS button". Do this.
5. Select "Restore File System". Follow the on-screen instructions.
!WARNING! - SELECTING ANY OF THE OPTIONS IN SAFE MODE CAN RESULT IN DATA CORRUPTION AND/OR LOSS. IF POSSIBLE, BACK-UP ANY IMPORTANT DATA BEFORE PROCEEDING WITH THE ABOVE PROCEDURE.
Hope this helps, good luck. If you require any further assistance, please contact me.
ajblaj
same issue
