Gutenprint driver does not work. computer will occasionally cause printer to make a noise like it might print. it doesn't print. the dialog box says that it did print. it did not. I've tried several generic ps and pcl drivers. shared printing with a Mac on OS 10.6 does not work either. Thanks!
SOURCE: Need a Mac OS driver
The above model does not support the MAC operating system.. Have any other queries please click on the below link..
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DPPFP55
Thank you.....
SOURCE: I am trying to print direct from computer to the
Make sure the PC option on the admin* tab is checked ON (default if off). *You enter the admin by tapping twice on the top left corner on the screen, and enter 9999 which is the default passcode. Contact www.kobis.com if you have any other questions
SOURCE: Cannot find the driver for mac for sony DPP-FP60
Export your photo from iphoto to a usb stick. Then stick that into the printer´s usb port. Use the menu of the printer to make any last corrections (size, brightness, borders etc). Works with both RAW and JPEG. Good luck. /Anders
SOURCE: Sony Printer DPP-fp90
You may use your memory stick option to print. I means you shall copy your pictures to a memory stick card. Insert in into the printer. And print directly without your MAC. I use Sony DPP-FP70. It works.
SOURCE: I have a sony snap lab UP-CR10L and it work and
It seems to be a driver problem which crops now and then and not a regular one.
Please uninstall and reinstall the drivers as per the link below:
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
