I can see the digital connector loose inside the camera. The connector looks like it has two tabs on the bottom that look like they should sit in two holes in what I think is a circuit board (green color). I can jiggle the connector around until it sits in those holes but connector won't stay in then as I try to connect the PC connector cable. Any help?
SOURCE: Canon Digital Rebel XT / EOS
In the communications option of the camera Menu, there are two options to choose from. Try changing the options. one of them works with Canon software to download images.
SOURCE: canon SD950 IS not turning on
The camera has to be taken apart. Your solution of shaking will always be a temporary repair and in the long run will most likely cause more damage.
SOURCE: Connection problem with Canon 450D to PC.
Use a card reader to download your pictures to a folder you create on your desktop.
SOURCE: Battery door latch broke off body of Canan A590
The same thing happened to me this week. I called Canon Canada directly and asked to order the part (The battery compartment door). They gave me a phone number to call and I was able to order the replacement door for about $8.00 + $10-$12 shipping. Hope this helps!
