certainly sounds like a fuse problem. First check that the fuses you have used work in another appliance. You should not have to use a fuse from the logitech company but it will be rated for your speakers so would probably be best. If the fuse checks out (both plug and amp) then check the wall socket and the power cable.
Have you got any more information on what is/isn't happening? No power, power lights on but no sound etc?
Back when I worked for a company that sold Logitech speakers the most common faulty with the X series was a small fuse that would blow. Usually the speakers would appear to receive no power at all if this was the case.
It's a $10 part if your speakers are out of warranty. Sometimes Logitech may even send this part out for free. Check your warranty though, in some countries there is up to 2 years on these speakers.
If it's a different problem, a little more information on the problem may help the FixYa community to give you some better advice.
I experienced the same problem, where the symptom was initially that the volume setting was misbehaving in that you would press the to increase the volume and it would go to the maximum, and likewise press the down button and it would go to the minimum volume. Then the screen appeared incomplete and finally it did not power on when pressing the power button. The solution I found was to unplug the power (overnight in my case) to allow any power to drain from the unit and transformers, and then plug it back in. It powered on afterward.
if no light came from the speakers then something is corrupted inside them .. you have to check the power source and power cable of the speakers first ... if everything is fine then the speakers are corrupted from inside
