Dell Inspiron 1545 Notebook Logo
A
Anonymous Posted on Jan 28, 2012
Where is the sleep button on dell inspiron 1545 laptop
PinkLisa
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Dec 24, 2017
PinkLisa
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
2932
Points
5
Please follow the steps mentioned below to set 'Power buttons and lid' options to sleep by using the power button and Closing the lid.
  1. Go to start screen
  2. Type in like this " power options"
  3. Select power options from the search results
  4. Select "Change plan settings" under the plan the radio button is selected.
  5. Select "Change advanced power settings"
  6. Change the options available of the 'Power buttons and lid'
  7. Click OK.
Also please refer to the link below for Dell Inspiron 1545 manual PDF.
http://downloads.dell.com/manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1545_setup%20guide_en-us.pdf
5 Related Answers
Anonymous
  • 130 Answers
  • Posted on Jun 22, 2009
SOURCE: Dell inspiron 1545 laptop and the same webcam problem.
open your my computer, click on "c" the system will tell you the information is hidden, click on the link and open up the operating system and look in the drivers or there in C and se if you can find you web cam driver, when you find it you might have to force the opening of the driver to install, and once you do that plug your web cam in and see if the system see's it and installs the drivers for the cam, if you installed the driver origanally witht he web cam installed you will have to remove the web cam and unistall the driver and re install it and then plug the web cam back in, and that should help correct the problem.
Anonymous
  • 87 Answers
  • Posted on Aug 30, 2009
SOURCE: When I close my Dell Inspiron 1545 laptop, it
Check your computer bios settings. There is a power managment section. Turn off power managment or set it to os controled. Check dells support site for any acpi drivers that you may need. These are needed for suspending controls.
Hope this helps.
Anonymous
  • 225 Answers
  • Posted on Oct 08, 2009
SOURCE: dell inspiron 1545 problem on installation,problem
1. boot to cd/dvd rom using the dell resource drivers utilities. you need to test the dvd drive if it is working, if yes, we might have 2 problems it might be the dvd installer or the hdd. run a test for the hdd to isolate the issue or you can try to run the installer to a diff computer to test if dvd installer is not faulty.
Mehandi Husain Suleman
  • 1654 Answers
  • Posted on Apr 25, 2010
SOURCE: blank screen on my Dell Inspiron 1545
if your getting your dell logo it means your disply is working fine
may be u r windows is not working properly just try to up-date your windows with any windows disk
Anonymous
  • 151 Answers
  • Posted on Apr 28, 2010
SOURCE: laptop dell inspiron 1545 no power up
Hello anourkhader
When was the last time you used it, and were there any problems? To find the solution to this problem is a matter of elimination. You should check the following:
Step 1 - Power
- Try an alternative power adapter
- Try plugging in your laptop to an alternative power supply
WARNING - BEFORE PROCEEDING, PLEASE FOLLOW THE FOLLOWING SAFETY PRECAUTIONS!
1. REMOVE THE POWER ADAPTER FROM YOUR LAPTOP
2. REMOVE ALL PERIPHERALS
3. WEAR A WRIST-GROUNDING STRAP, AND CONNECT IT TO AN UNPAINTED, METAL SURFACE. IF ONE IS NOT AVAILABLE, TOUCH AN UNPAINTED METAL SURFACE TO DISCHARGE ANY STATIC FROM YOUR BODY
Step 2 - Remove and reset basic hardware items
Remove and reseat the items mentioned below in the order they're mentioned:
- AC adapter
- Battery
- Memory
- Hard drive
For instructions on how to do this, please refer to your user manual. If you no longer have it, you can download it from here: http://support.dell.com/support/edocs/systems/ins1545/
If after following the above instructions, your laptop still doesn't turn on, I would recommend that you contact Dell customer support, which you can do by following this link: http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?
I hope this helps. Please feel free to contact me if you require further assistance.
ajblaj
Usually when you close the lid on your laptop, it will go to sleep mode. The second light is orange and blinks when it is in sleep mode.
Dell inspiron 1545 goes to sleep while in use
The solutn is...please uninstall..the AHCL driver from ur pc..then the problm is solve...try it...thank u..
Inspiron 1545 hibernates often. How do I fix this. The OS is Vista
RIGHT CLICK UR BATTERY ICON ,GO TO PWER OPTIONS LOOK FOR ADVANCE SETTINGS ,IN THE BOX LOOK FOR SLEEP ,EXPAND , SLEEP AFTER ,CHANGE TO NEVER THEN HIBENATE EXPAND THEN CLICK NEVER SEE IF THAT HELPS U
Hello, my brand new (2 weeks) DELL 1545 laptop is going into hibernate/sleep mode, 10 times in the past 1 hour 1/2???? It is NOT shutting down, just have to turn the power button on and all is back to...
goto the control panel - power options and see what you have set there for sleep mode, under the powerplan - often it can be set on a couple of mins when using battery change the setting to longer
1helpful
How do I eject a CD on my Dell Inspiron 1545 laptop? I do not see aqn eject button.
If you can see the media buttons it's the middle button that has a triangle icon. that is the eject button for the CD/DVD drive.
7helpful
2answers
Dell Inspiron 1545 Broken Screen?
The LCD is definitely shattered, looks like pressure was applied from the back of the screen (Pressed on, laid on etc) and the LCD will need to be replaced.
Several are available on Ebay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+1545+LCD&_sacat=See-All-Categories
Service instructions are here
http://support.dell.com/support/edocs/systems/ins1545/en/SM/display.htm#wp1183775
When I close my Dell Inspiron 1545 laptop, it always shuts down, even when I set it to sleep mode. This causes Windows to shut down incorrectly among other problems.
Hope this helps.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
