Check the fuel cell first, there is an expiration date on the bottom and out of date fuel can cause a problem. As far as repair it depends on where you are located. You can try going to somebody like Lowes or Home Depot and asking them or look in your phone book under tools repair for a local service repair center that might be able to fix. If you are around Ohio I can help you with the problem.
SOURCE: paslode nail gun not firing
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
SOURCE: NAILER WONT FIRE NAILS
DO NOT USE WD40 . Is The Nailer fireing? If Not check the micro switch by the fan . Make sure it is pushing on the switch.. Otherwise bend it a little
SOURCE: nail gun won't fire
Try this. Take the handle off the tool per the cleaning instructions. Install the battery and push down on the roller lever in the upper handle. It's located close to the fan blade. (Item 27 on the tool schematic.) Keep your finger out of the way or the fan will bite you.
If the fan goes on, then the roller lever is bent and needs replacing or adjusting.
If the fan does not go on, release the lever and pull the trigger. If the fan works, then the molded circuit board needs to be replaced.
SOURCE: my paslode nail gun gets jammed and does not fire
you need to clean the piston and make sure it is free of debris with a degreaser and then relube it lightly and it should work properly
SOURCE: Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Testimonial: "Thanks for that, i will look into it! Thanks for your time.... Cheers, Steven. ;-)"
1 is there a test i can do to be sure the sparking unit is gone have replaced plug and lead stil not fire fan comes on but when press trigger no spark
you have to depress the roller lever first and then the trigger. the roller is below the fan housing. depress and hold it while depressing the trigger. Make sure the terminal block by the switch is fully seated. Other than that unless you have a spare one there is no electrical test that I know of for the spark unit. They are not cheap. If you take it to a repair shop usually you can talk them into trying another unit before buying a new one..
