Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
CJSCH Posted on Jan 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reset my password for wireless router?
Level 3:
  • Netopia Master 7,733 Answers
  • Posted on May 29, 2014
Netopia Master
Level 3:
Answers
7733
Questions
0
Helped
1864846
Points
21487
Forgotten password for wifi network
Which operating system ??
Your wireless Internet password is the encrypted security pass phrase that was set up when you installed your wireless router.
Your router allows you to access the Internet.
If you have access to more than one wireless network, you may need to remember multiple passwords.
If you happen to forget one password, you have two options: reset your password or locate the current password.
Windows 7 allows you to view the security characters of all your wireless network passwords.
Click the "Wi-Fi" network icon located on the Window's taskbar.
Right-click the name of your network's "SSID" name and select "Properties" from the drop-down menu.
Click the "Security Tab." The network security key is now visible but unreadable.
Click the "Show Characters" check box and this will reveal your wireless password.
http://www.thewindowsplanet.com/939/how-to-recover-wi-fi-network-key-in-windows-7.htm
or
Reset My WiFi Password
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser.
Enter the default address of your router.
The default address is listed in your user manual or on the product website.
Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings. Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
How To Reset Your Router's Password
http://www.lostintechnology.com/how-to/how-to-reset-your-routers-password
How do I recover a forgotten password for an overdrivepro63E wireless internet stick
Open your Web browser. Enter the default address of your router.
The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
How do I reset my password?
Step 1:
Wireless networking is a common feature in homes and offices. Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network. If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu. Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable. Open your Web browser. Enter the default address of your router. The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1." Enter your username and password. Many routers use "admin" for the username and password by default. Locate the wireless security settings. Disable the wireless security. Reset to Factory Defaults Locate the reset button on your router. Typically the reset button is a small indented hole on the back of the device. Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings. Open your Web browser. Enter the default address of your router. The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1." Enter your username and password. Many routers use "admin" for the username and password by default. Locate the wireless security settings and add security as necessary.
4helpful
Reset password to the router and get a new one
Are you trying to reset the router password or wireless network password?
Wireless network password is different than router access password.
To change the wireless password, you will need to access the router page and change the settings.
See how to find wireless network password
To change the router access password, you can log in to router page and go to administration tab. There you will find the place to change the router password.
2answers
Forgotten password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Tried to reset password..seemed easy enough,done.. reset router name easy, reset password easy. reset ssid easy..in fact my password was the same for everything to make things easy. Now i go downstairs...
Router paswords are chase and space senitive, Reset the router and choose a different password that not been used. then repower the router, and connect using the new password.
2helpful
2answers
I forgot my password
If you have forgotten the router password you can reset it.
To do this, turn the router upside down and look for a small pinhole that says reset. Get a stapler and press and hold the reset button for 5 seconds.
The router will reset to factory defaults and you will be able to login again using the default username and password. For linksys routers is "admin" for both fields.
3answers
Forgot linksys router password
Reset the router. Thats the only solution.It will get back to facotry defaults.
Thanks
Ranjit
1helpful
Yeah hey...belkin wireless router password reset
What is the brand of the router your using? This information will be from the router that you have. Use a wired connection from the router,check your default gateway (ipconfig) and type that numbers in your address bar. You will be able to access your set-up page, look for wireless tab and look for wireless security. You will see there your WEP key.
Top Netopia Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
