Question about Stanley Fatmax Xtreme Retractable Utility Knife
10-780 Stanley Fatmax Xtreme Retractable Utility Knife
2 Suggested Answers
SOURCE:
SOURCE: Just purchased a Stanley FatMax 10-778 retractable
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Posted on Apr 11, 2010
Testimonial: "Thanks so much!"
Can't close stanley fatmax
It only goes in one way, try to loosen the screw a little
Jul 30, 2012 | Stanley Fatmax Xtreme Retractable Utility...
I have a stanley FatMax. How do I insert the blade into the case?
On the side there is a big gold wheel, twist counter clockwise and the case should split in half, the blade is held by a magnet, prise the old blade off and replace with new one, then put case back together and tighten gold wheel clockwise
Mar 06, 2011 | Stanley Fatmax Xtreme Retractable Utility...
Can i buy a new blade slide for extreme utility knife
I can't see what country you live in from your profile, but if it's the UK, you could try www.partmaster.co.uk . They sell parts for just about anything.
Feb 28, 2011 | Stanley Fatmax Xtreme Retractable Utility...
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Dec 23, 2010 | Stanley Fatmax Xtreme Retractable Utility...
How do I put the first blade in the new knife?
open the blade all the way and turn the knob to loosen, then scissor the two halves to open
Oct 22, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Change blades I just need a picture /instruction for blade change
The gold looking circle on the side of the utility knife. Just unscrew that and it will pop open then you can change the blade. I looked everywhere and am unable to find the instruction or picture. I own one and that is why I am answering this for you. Please rate
May 31, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Just purchased a Stanley FatMax 10-778 retractable knife. Cannot figure out how to load the blade for use.
good luck
Mar 20, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I brought a stanley fatmax retractable knife, have no idea why the blade is not coming out, trying to figure out if i did something wrong like putting the blade in the wrong spot.. this is the only time...
Are you using Stanley Blades or off brand? Hey, I use off brand but sometimes it does make a difference. Second, make sure the blade slider is clean. If you were cutting shingles, for instance, the tar gets in there and screws things up.. try WD-40 spray it liberally all over the blade slide and buttons. If that doesn't work and you purchased it at a Menards store, I can speak of experience they'll replace it no hassle.
I hope I helped
Jan 09, 2018 | Stanley Fatmax Xtreme Retractable Utility...
Stanley Fatmax Xtreme Retractable Utility Knife Logo
75 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Frank Walton
Level 1 Expert
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
