I believe it could be the phones file system that could be at fault here.
Take out the sim card and get the keypad up when the phone has started, type in the following code: *2767*2878# Which will take the phone back to Default settings and reconfigure the file system.
If that fails reboot the phone without a sim card and then try the following code: *2767*3855# The code above will remove all data on the phone and will be set back to Factory condition.
If neither of the above work then you will need to have the phone flashed (firmware reboot) at this moment in time im in work and unable to check if there is a 3rd party flasher for this interface, alternatively if you have a local mobile phone repair shoip they should have a kit called NS Pro which is fully capable of flashing the phone.
And if akll fails then the chipset on the phone may be damaged itself either from moisture or being dropped.
Hope you have bricked your android phone. Now must flash your phone with stock rom. You can do these by using ODIN. Just download ODIN for your phone, download stock rom odin flashable .zip packages for your phone, put your phone in download mode, connect your phone to PC via USB cable, run ODIN , load stock rom packages, flash it..
the problem is as a result of software corruption. Your phone operating system is corrupt for one reason or the other. The phone operating system might have gotten virus through bluetooth transfer, internet browsing or via the memory card.
To solve the problem, you need to flash the phone . Flashing the phone means reinstalling the phones operating system software files. The phone will be fully formatted and a fresh operating system files will be reinstalled.
You can use software updater to flash the phone. Download software updater from motorola.com. Install it on your computer, open the software updater, connect the phone via usb cable to your computer. Allow the computer to recognize the phone, then click update. Follow all direction from the software updater application. And your computer must be connected to the internet.
Hi, when a phone it is continuously rebooting, it means that memory has been affected by VIRUS.
VIRUS can damage a phone in no time. VIRUS can be caused by downloading applications on your phone through the internet, or might be from data transfer from a phone to another phone.
To remove the VIRUS, you will need to flash the phone memory. Flashing the phone will restore back the phone to it normal state.
You can use this link to see how to flash your phone
Flashing a cell phone will erase carrier data from the memory. Cellular companies can usually do this for a fee. Online buyer sites sell the software kit that will flash a cell phone from home computers.
To flash a phone you will need to rewrite the PRL file by connecting your phone to a computer with the needed equipment. Your best bet is to take your phone to a dealer that flashes phones on a regular basis. For more information
The inactive feature response means that the phone system and the voicemail are not communicating with each other. I would first check that the voicemail is powered on. If it does have power, I would reboot it by unplugging it for a minute and then plugging it back in(startup can take 15 minutes).StarTalk, Flash, and NAM are some of the names of the voicemail units for small to medium size Norstar phone systems. Occasionally, both the phone system and voicemail need to be rebooted to allow the two to sync up and "see" each other. Occasionally the Norstar voicemails go bad where they will not power up or after powering up they cannot complete the boot up process or after powering on and booting up they will not answer when called. If your unit will not work after trying to reboot a few times, I would recommend you consider having the unit repaired before replacing it. If you need advice on where to send for repair, send a comment and I will help.
VIRUS
That means that the voicemail system is no longer recognized by the phone system. Check the lights on the voicemail to see if its still receiving power.If so try unplugging and plugging the voicemail to reboot it. The voicemail can take up to 6 minutes to totally reboot.
When the power is re-instated to the system all arrows will flash on all phones while the boot up process takes place. This could last up to 10 minutesto fully reboot depending on the size of your system.
win flashing a phone
