I don t have dissc to instal lexmark z 640
Please visit the Lexmark website to download and install the
Lexmark Z640 Printer Driver on your computer. Select your operating system
> click on "FILTER" > click on the driver under Recommended
Downloads > download and execute the file. Simply follow the instructions on
your computer screen to complete the installation.
SOURCE: Broken Lexmark 640 installation disc
Lexmark does not distribute replacement install disk for all models, but many models are available.
Contact Lexmark here, to see if the disk for your printer is available.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if
you get in troubles, follow
the instructions below to reset and reinstall drivers:
Note:some
printerdoes not work on Vista, if you do not find any driver download
for Vista on your model page, that means your model is not Vista
compatible.
SOURCE: Lexmark 640
This one is easy...
Turn printer off
Before powering on, hold down the button with a check mark on it and the directional button to the right of it..
Power printer on, still holding down said buttons...
wait 15-20 seconds and release... when the printer finishes booting up it will be in config mode
(if you get the error 80 scheduled maintenance, hit the go button)
hit the down button once... you will see then reset maint counter. Hit the menu button ... you will see something to the effectof reset with a check mark next to it..
Hit the menu button again and you will see it say reset. Then hit the back button till you get back to the main menu and use your up/down arrows until you find exit config menu. Hit menu and it will reboot itself right back to the regular screen.
Hope this helps,
