We lost the remote to this tv and can't removed the closed captioning. We put this on another remote that works with the vcr too. We know the menu can come up when we push the buttons on the front of the tv but there seems to be no closed captioning option. We need help - tired of having much of the screen covered with closed captioning now for over a month! Thanks for any answers.
SOURCE: cannot get 27" magnavox closed caption
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
SOURCE: cant turn off caption on tv
There are several universal remotes on the market that can be programmed to work this function on your TV, one that comes to mind are the Logitech Harmony remotes. The great thing about this remote is it will work for any device in your house. The down side is they are 100$+.
Now if you simply want to turn off CC with the remote, and then take it back to the store, then that could work too! ;)
Another option would be to leave the TV completely unhooked for a while, hoping to "clear" and memory on the TV, resetting closed captioning back to the factory default. A lot of older TV's also would have a reset button, usually behind and door that could accomplish this. There is no guarantee that this would even work though. I think the safest bet would be a new universal like the Harmony.
Cheers!
SOURCE: i cannot get closed captioning to turn off and
I have the same problem, but I cant even get a code for my universal remote to access my menu or any of the settings. Dont think I will buy Philips/magnavox any more.
SOURCE: Turning off Closed Caption
Are you using a cable/satellite box or just basic cable service?
When you go to the menu what options become available to you?
If the following options are present-
smartlock
setup
cc
If not try to press both the volume buttons on the front of the TV at the same time and see if the above options become available.
If so use the channel down button on the front of the tv to scroll to "cc"
Once CC is highlighted use the volume + button until it says CC off.
If these menu options don't become available please reply what options are shown.
Good Luck.
Not all TV programs and product
commercials are made with
Closed Caption (CC) information
included. Neither are all Closed
Caption modes (CC1, or CC2) necessarily
being used during the transmission
of a closed caption program.
Refer to your area's TV program listings
for the stations and times of
Closed Caption shows.
To close the close caption display from screen; press "CC" button on the remote control.
