Frigidaire ATF6000ES Front Load Washer Logo
Posted on Oct 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire front load washer (LTF600ES1) Error E20
Can someone please tell me what error E20 means and how to fix it? It comes up within 10 minutes of the wash cycle. I removed all the clothes from the machine and pressed start. It tries to drain water and will not go past this cycle. If I set the washer to spin only it will drain and spin in that setting, but not when washing. Thanks in advance for any help. I think I can fix the clog in the pump if I could get the front panel off the machine! Any Ideas????
jason
Level 3:
  • Master 905 Answers
  • Posted on Oct 18, 2008
jason
Master
Level 3:
Answers
905
Questions
8
Helped
320945
Points
2511
This is an error that indicates the tub is clogged or draining slowly
to fix this you have to go under the washer and pull the tub hose off and clean all obstructing stuff in the hose and thru the hole on the tub
  • jason Oct 18, 2008
    also the water pump may be clogging up
Ginko
Level 3:
  • Frigidaire Master 19,396 Answers
Ginko
Frigidaire Master
Level 3:
Answers
19396
Questions
25
Helped
8074932
Points
55462
Http://www.fixya.com/support/t615626-error_code_e20
  • Ginko
    Ginko Oct 18, 2008
    Sorry wrong link.
    E20 is a problem with the drain system, start inspecting the drain hose, if it is not clogged, then the drain pump is either clogged or faulty.
    See the instructions here.
Anonymous
Level 3:
Genius:
  • Master 3,422 Answers
Anonymous
Master
Level 3:
Genius:
Answers
3422
Questions
Helped
1025019
Points
9479
HI,
E20 is a problem with the pump, or drain hoses.
remove the 2 screws on the bottom and the front access panel comes off
pump is on the right, remove hoses from it, remove pump from machine then remove whatever is in the pump
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
What does the error message E20 on the frigidaire front load washer GLTF2940FS mean?
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
1helpful
My frigadare front loader has code E20 on it and won't drain out all water from clothes or drum
Hi
Error code e20 means a clogged drain pump. This might have happened due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump. Hope this helps... Please post back for any further assistance.
Daniel
5helpful
WHAT DOES E20 MEANS ON A FRONT LOAD
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then clean the debris from the pump. Make sure that you have a container to collect water nearby when you are removing hoses from the pump, as ther would be a lot of water. Please post back for any further assistance.
Daniel
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Daniel
1helpful
Error code e20 model # gltf2940ee0
Hi
Daniel
E20 error code
Check this answer:
http://www.fixya.com/support/t615626-error_code_e20
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Your washer is not draining properly. You need to check if the drain hose is kinked and also whether the household drain is running smoothly.
1helpful
E20 Error
On the sheet, 2 beeps and error E20 says Water Doesn't Drain. Drain hose is kinked or household drain is clogged. Straighten hoses or unclog household drain.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
