RCA HD52W58 52" TV Logo
John B Posted on Oct 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RCA D52W20 I have an RCA model D52W20, and I need the part number for the green CRT board (the board that connects to the middle (green) tube). The numbers from the board are GRNHYB-570 DM4 18419413642992 Thanks for any help!! John
Anonymous
Level 2:
Scholar:
  • Expert 146 Answers
  • Posted on Nov 10, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
146
Questions
0
Helped
42203
Points
226
That board is called a Green Kine Drive pcb. The part number is 266860.
1helpful
Have a 52 in HDTV from RCA, if you urn it on the light comes on green then it cuts off in a few seconds, does this over and over. No sound or picture
sounds like your green tube is overloading. overdriving...this could be a number of things relating to high voltage driving the green tube. tube replacement in thes sets have become not cost effective. tube about 250 for the tube plus anothe 200 for labor. might be high voltage block or the crt driver board.
I have a 52 in RCA Plasma TV and when I turn it on nothing comes on but just sometimes a green blank screen with no sound and sometimes power goes on and off. Ive hired an technician to look at it last...
The RCA D52W20 has three picture tubes the problem you describe is symptomatic of a shorted or a bad green tube. other problems could be bad crt boards. high voltage block, In the case of tube replacement i often suggest the cost of replacement is more than the set is worth. so i would suggest getting a second technicains opinion
TV COME ON ITS RED SCREEN THEN TURN OFF
Red CRT board either tube is Bad or Bad video Ic on the Red CRT board it connects to bottom of Red Tube for CRT Board Call Encompass Parts
1-800-638-3328
I have a rca model d52w20 52in rear projection with green screen the green tube has been replace and the board at the bottom of the tube has been replaced also and it still has green screen and a humming...
can you pull the green crt board and carefully check to see if the 200volt supply is present that one cause for over satuations of the crt if it is not there you need to trace back for the cause
2answers
D52W20BYX1 Green problem
I would go back to green tube disconnect ,unplug CRT board to green tube if set stays up playing its the tube.
2answers
What is part number for main power supply board on a model#d52w20 rca
you have to open the TV up and it should be on a white sticker on the mother board.if you do not find it google RCA model #d52w20 main power supply board
Tv shuts down after about 5 seconds
Sounds like the green CRT has a short.If you unplug the socket from the green CRT tube (the one in the middle) and power up the TV and it stays on then it will verify that you need a new green CRT.
Green lamp goes out within minutes of turning on tv
Check CRT board the Video IC on it can be bad so you do not have to replace Tube be Very carefull when you remove CRT board from Neck of Green Tube so you do not Breck it. Check all 3 tubes make sure none of them are leaking out coolent fluid.
RCA D52W20 Blue Tube doesn't power on
From your description it does sound if the blue crt has failed. But it can be the crt board or a high voltage issue. intermittantly like that could be a connection problem. is there any hissing ..cracking or smells?
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
