The manual on page 126 says:
Image Database File error Cannot recover Import all of the images to the computer with "PMB", and format the memory card or the internal memory (page 97). To view the images again with the camera, export the imported images to the camera with "PMB".
If you used the card before in the same camera, it should be compatible. If you can't save the pictures normally, us an external card reader, to save or recover and save the pictures first. Then do a format in the card reader (FAT or FAT32) and when you reinsert the card in the camera, again format the card, this time in the camera. (You always should format in the camera, the first time you use a memory card in a camera, or after you had a failure tithe the memory card.
After you inserted the Compact Flash card, you have to format the card in the camera. If it was used in another camera there is always a possibility your camera can't read the existing file system. Make sure you saved all pictures on the card, in a computer, using a memory card reader. Only then format the card in the camera. Then you first have to shoot a picture, before you can see one.
Make sure you close the memory card cover, before you try to do anything with the card.
Never open the camera, or remove the battery, while the memory access light is still flashing. This could damage the filesystem.
If you already did so, try to recover the files in a card reader connected to the computer. There is free recovery software on the net.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
If you can connect an USB cable to your camers and then plug the cable into the USB port of your computer, it may see the camera and menory card as an external storage device and you maybe able to open the folsers on the memory card to download the photos. If this does not work the you need an USB reader, (they are not expensive). When you use an USB memory card reader and still have difficulty in retrieving your photos then - Recuva (pronounced"recover") is a freeware Windows utility to restore files that havebeen accidentally deleted from your computer. This includes files emptied fromthe Recycle bin as well as images and other files that have been deleted byuser error from digital camera memory cards or MP3 players. It will even bringback files that have been deleted from your iPod, or by bugs, crashes andviruses!
Simple to use interface - just click 'Scan' and choose the files you want to recover
Easy to use filter for results based on file name/type
Simple Windows like interface with List and Tree view
Can be run from a USB thumb drive
Restores all types of files, office documents, images, video, music, email, anything.
Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
Restores files from external ZIP drives, Firewire and USB Hard drives
Dynamite, have you tried to reformat the CF card? If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
In general, the file size of captured image depends on which image size and quality you have selected. Since the image size may vary depending on scenes and subjects, these are approximate values only for 8MB Compact Flash. Economy: 47/178 Standard: 24/10
