I need to replace some faulty capacitors on the monitor power supply due to it "whistling" but I can't figure out how to open the case!
There are locking tabs, if you can get a thin a putty knife in between the 2 parts of the shell, in good lighting you can see the first one, and you can press the tab in with a small screw driver which should release it, from there it is a matter of finding the rest of them. Starting from a corner, chack about 2 to 3 inches from the corner. They will be located in a symetric manner.
Testimonial: "Thanks very much for your advice!"
I've managed to get the back off using the advice given, but I now need to get in to the metal case behind this, to do this it appears that I have to split the grey surround from the black polished front - any ideas?
