The issue you have posted regarding that you are unable to open and use the I internet explorer showing error message “ iexplorer.exe ” can not open and needs to close could be due to number of reasons, The steps mentioned below generally fixes these kind of issues I would appreciate if you could try them to get iexplorer.exe issue fixed.
FIX I.
- Click On Start, point to Internet Explorer and then right click on the Internet option and left click on properties.
- Click on the Delete tab under the (temporary internet files)
- Click on delete temp internet files after selecting delete all.
Fix II.
- Click on start, point to control panel and click on it.
- On the Control Panel window, locate the Add/Remove software icon and click on it
- Locate the option Add/Remove Windows Components on the left side of the window and click on it.
- Locate the Internet Explorer option form the list and remove the Check Mark in the box by clicking on it, then click NEXT at the bottom. (This will Uninstall the Internet Explorer)
- Click on finish.
After you perform the above mentioned steps, restart the computer.
After the computer is restarted and when it gets back to the desktop screen perform the following steps.
- Locate the Internet Explorer option form the list and then Check Mark box by clicking on it, and then click NEXT at the bottom. (This will reinstall The Internet Explorer)
- Click on finish.
Restart the computer and check if you are able to open the Internet Explorer works.
Fix III
This issue can also occur if you have installed any third-party internet tool bar for example, Google, Yahoo, or Rediff etc so you can uninstall the tool bar form the Add/Remove programs, however you will not have to go into the Add/Remove windows components option, the tool bar software will be displayed on the screen which comes up once you click on the Add/Remove icon in the control panel. All you need to do is to select the toolbar and click on remove in order to uninstall it.
Fix IV
- Click Start and select Run.
The Run window appears.
- In the Run window, type msconfig and click OK.
The system configuration utility Window appears.
- Click on the option Startup at the top right hand corner.
- Click on the option disable all at the bottom of the screen.
- Click on apply.
- The system will request to restart, click on restart and let the system restart by itself.
- Once the system restarts it will prompt you a screen after it logs in, stating that the startup has been modified and it asks you weather to show that screen again, so select do not sow the screen when logged in next time and close the window.
Should you require any further assistance regarding this issue or any other computer related issue in future please feel free to contact get back to us, we will be more than glad to assist you.
Regards
Malik Khan
my computer programs don´t open
