Question about Polycom VSX 7000 Video Conference
Why does our office Polycom system go dark when no one moves?
It seems as though the system goes into some sort of power save mode or energy save mode. The picture becomes darker or dimmer when there is no movement for a period of time. For example, during meetings with our east coast office, at a certain point in the meeting thier video picture, which we are looking at, gets darker or dimmer. It seems to happen when no one gets up and moves for a while.
    Top Expert:
  • Polycom Master
  • 51,852 Answers
There could be an automatic timeout when no movement is detected. The solution is to have everyone keep moving, even breaking into a lively dance from time to time.
Posted on Aug 12, 2017
2 Suggested Answers
SOURCE:
  • 5 Answers
SOURCE: Polycom VSX 8000-- cant hear
If you cant hear anything then this is a firewall issue not the VSX8000. Call us for port openings. 415.637.9989 . If the unit works on a LAN but not outside your firewall this is what it is. If it does not work on a LAN then it is the VSX8000..
Posted on Apr 21, 2009
Polycom spectralink 6020 voicemail
All depends what phone system the Spectra runs along side with, call your vendor who installed it or your office manager/admin
Nov 17, 2012 | Polycom SpectraLink 6020 Wireless...
How to fix Polycom soundpoint IP 335 with surge damage
The IP 335 is an entry level phone so it is doubtful that there would be anything like a fuse in it. From what you've described here I would say the phone is fried. Moving forward I would recommend to always keep your important electronics on a good quality surge suppressor and/or a UPS. Good luck.
Jun 26, 2012 | Polycom SoundPoint IP 335 IP Phone
My E520 Dell shuts down in to the energy save mode after 1 minute of booting and then the high speed fan comes on and screen goes black
off the energy save mode...it goes revert of ur action...re-install opreating system..is it work? clearfy
Mar 16, 2012 | Dell Dimension E520 PC Desktop
My IBM screen goes dark after being on for several hours. It will return to normal, and then go dark again. Could this be the HDD is getting too hot? Is there a way to increase the fan speed?
Check the energy save settings and see if the monitor is set to shut off after a certain amount of time. Also if the laptop battery gets low it may start to turn off the monitor to save energy. Are you using the computer on a/c power or battery power when this happens? As far as fan controls the settings are usually in the bios but you can sometimes install software that will control the system fan. The BIOS system menu is usually available by pressing delete when the computer boots up(some computers are different button).
Sep 08, 2009 | IBM ThinkPad 570E Notebook
Monitor keeps switching itself off
Switching itself OFF to me it means even the LED light at the front goes OFF. If that's the case, you may have a hardware problem. However, if the LED changes color, chances are your monitor is gone to "sleep mode" in order to save you money on energy. If the latter is the case, simply moving the mouse of pressing any key on your keyboard brings the display back. Try that.
Energy saving is controlled by your Operating System, Windows or Mac. Look in the Control Panel for Power Management or similar category. In Windows, these settings can be found and are related to Screen Saver. Look there first.
Aug 25, 2009 | Xerox Computers & Internet
TOM TOM GOES BLACK WHILE DRIVING
It appears that you do indeed have the system on energy save, go back into set up and un check power save mode.
Jul 07, 2009 | Tomtom GO GPS Receiver
CLEANS ITSELF TOO FREQUENTLY- 2-3 TIMES EACH DAY
Try maxing out your power save timers. Here are the instructions. I suspect the machine is going into power save mode to quickly. Here is how you do that.
NOTE: To save energy, the printer enters a power saver, low-energy consumption mode after a predefined period of time since its last activity. In this mode, most printer electrical systems are shut down. When a print job is sent to the printer, the printer enters the Warm-up Mode. You can also warm up the printer by pressing the [OK] button on the Control Panel.
If the printer is going into Power Saver mode too often and you do not want to wait while the printer warms up, increase the length of time before the printer goes into the Power Saver mode.
Modify the timeout value:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Printer Controls], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Power Saver Timeout], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select the required timeout value (30 - 240 minutes), and then press the [OK] button.
    NOTE: Select a larger timeout value to extend the length of time before the printer goes into the Power Saver mode.
  5. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
Feb 02, 2009 | Xerox Phaser 8500/DN Printer
Power save mode
I had the exact same problem but it is fine now! :) And this is how you solve it .....you press the power button (single press), and a series  of options come up...if you scroll down them you will come across a 'deactive power save mode' option, click select and this should sort it out!
Hope this helps! :)
Jan 15, 2009 | Nokia N96 Smartphone
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Nov 17, 2008 | Dell E173FP 17" LCD Monitor
Monitor goes into energy save
try going into the controlpanel,display,then on the screensaver tab click on the power button and check settings
Apr 23, 2008 | Dell Dimension XPS PC Desktop
Polycom VSX 7000 Video Conference Logo
69 people viewed this question
Top Polycom Lands Phones Experts
Joseph Wright
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
