Dryers Logo
Posted on Jan 26, 2012
Is there a reset button on my creda tumble dryer model t622cw
Margaret Tippet
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 15, 2019
Margaret Tippet
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1215
Points
Hi is there a reset button ?n Freda 1700/20W
3 Related Answers
Anonymous
  • Posted on Mar 11, 2009
SOURCE: drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 16, 2009
SOURCE: Creda T622CW condenser tumble dryer drum wont turn
You need to check if the belt is o/k.
Remove top cover, and grasp belt, it should be firmly wrapped around drum.
If o/k, then could be a motor problem, or programmer fault
Once you have got the drum turning again, it is possible the filter light will go off,if not, then you have another fault
Hope this helps.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 27, 2010
SOURCE: creda simplicity condensor dryer
You need to replace the door interlock or switch as it is better known.
You could spray inside the switch opening with WD40, before replacing switch, as it could be just sticking.
Please rate my solution.
Thankyou.
1helpful
CREDA T601CW DRYER POWER USAGE RATING
The element is 2,500 watts. The motor will add another couple of hundred.
Creda T601CW Tumble Dryer Spares
4creda https://www.4creda.co.uk > tumble-dryer > catalogue
Creda T601CW Dryer Heater Element 2500W. Genuine spare part. Creda T601CW Dryer Heater Element 2500W. Also Known As: Heater Element 2500 watts Heater Elements ...
Dec 18, 2023 • Dryers
Hi does anyone have aCreda t622cw tumble dryer wiring diagram, I've had it all apart to clean it all out and pulled all the wires off from the front panel.. I took photos but they got corrupted.. As you...
THIS LINK MAY HELP. INTERNET SEARCH MAY TURN UP OTHERS OF INTEREST. MOST UNITS COME WITH
WIRING DIAGRAMS. A DIFFERENT MAKER'S UNIT I WORKED ON HAD THE SHEET IN A CLEAR PLASTIC ENVELOPE ATTACHED TO THE REAR PANEL. A USED APPLIANCE STORE MIGHT LET YOU BORROW ONE.
< https://www.manualslib.com/manual/33161/Creda-Tumble-Dryer.html >
Jan 27, 2019 • Dryers
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 • Dryers
1helpful
Creda simplicity condensor dryer model no T622CW.Problem, dryer continues to turn when door is opened.Which part(inc part No) do I require?
Thankyou.
Jan 27, 2010 • Dryers
Hope this helps.
Dec 16, 2009 • Dryers
Tumble dryer wont dry
hi do you have any blockages in the vent system (lint) can you hear the fan running and are the filters clean.did you put it back together correctly.hope this helps.
Mar 05, 2008 • Dryers
3answers
Thermostat wiring diagram for creda t622cw
I assum there are four wires, you really cant get them wrong as they are all Neutral wires so it won't go of bang, it just may not heat as it should, I would connect them as you think it should and try them.
Dec 02, 2007 • Dryers
4answers
Drum wont turn on my creda t622cw tumble dryer
Nov 15, 2007 • Dryers
Top Hotpoint Dryers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
