What does this error code mean?
SOURCE: l43 relay board message on dacor millenia double oven
HAS ANYONE SOLVED TEH L43 RELAY BOARD MESSAGE?
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: Dacor Oven F4 error message
Hi. I recommend Checking the sensor wiring harness and harness connection between the oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
SOURCE: Dacor error codes
I had the error code F 0.
I unplugged it and plugged it back in.
This fixed my problem.
Here is a link to Dacor's error codes.
http://www.repairclinic.com/0078.asp#Dacor
SOURCE: ECS227 Epicure Electric Double Oven: I have a Dacor model # CPD227R double convection o...
replace touch pad
