My Genx Samsung flash disk 4GB is not opening because it has virous inside it. so when i put it in my computer he tell me to do format.then i do format for it , but he say it can't complate .....
Try it on an other computer... if that fails, it might have developed bad sectors (spots) reformat and do a scan, which writes and reads all memory locations... might be corrupted and/or broken, but try another computer first to make sure it is not a driver issue.
are you the computers administrator? click start right click on my computer select open Right click the icon of your Flash Drive (It should be F: or E: or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control.? click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers if you can see your usb drive but its not working ports(com&lpt)right click update driver click start click on my computer you should see your usb drive right click then select format another way is to control panel administrive tools computer management disk management right click on your drive select format hope this helps you
theres a few things you can do, when you do format your memory stick make sure you format it to the default settings. Also make sure everytime you put files onto your memory stick that you remove the memory stick safely you can do this by right clicking the memory stick and pressing eject. However the problem could be that your memory stick is corrupt.
the most defalt of option is reinstal the driver and check in the Device Manager the usb you have 3 usb root hub,1 enhanced pci to usb controler,update and try again,it should work.
the problem is from your memory IC inside the Flash thats why refuses to format due to cold solder or some pins need fresh solder. so many times i fixed these kind of problem not only Genx.
If you dont care about the data then you can just erase it either by right clicking on the drive and going format / erase or right clicking on my computer --> manage --> disk management --> right click on F drive or the memory stick and then select format / erase
