Had a hornets nest block the fitting up on it took it apart and i cant tell if ive lost parts there was a spring and ball bearing that works the triger?
SOURCE: how can i take apart my impact wrench and rebuild
if you need to ask that ,i dont think it would be a good idea.they are quite fiddely and many parts can go in 2 way but only 1 is right and some of the o.rings up in the trigger area are abit difficult. it wouldnot cost alot to get it serviced at an airtool service centre, and that would be my recommendation.
SOURCE: want to re assmbly it
I took it all apart and cleaned it all, reassembled,oiled it and now it is as good as new.
\Thanks for your interest
SOURCE: Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
