For recording audio in high quality, using Linux freeware such as JACK, Linux Sound Studio, etc. wondering if s/pdif will be better quality and cheaper than USB input devices
SOURCE: no sound on my dell optiplex 330
Unless you have headphones, you need speakers, preferrably amplified speakers.
Another way the address the issue is to use a cable to connect your computer to your home stereo if it has an auxilery input (aux/cd/tape input) then all you need is a cable with two male RCA plugs on one end and an 1/8 inch stereo plug on the other end.
The 1/8th inch plug goes into your computers' sound "out" and the rca's go into the aux/cd/dvd "IN" on the stereo.
this cable can be purchased for under 10 dollars at walmart, though amplied speakers wont be much more expensive.
Hope this helps you decide which direction to go..
Regards..
SOURCE: No sound and audio device
Download and re-install audio driver from dell website.
It should fix the problem.
SOURCE: My microphone not working on my dell xps 420 vista system
double click on the speaker and make sure that the mic does not have the mute box with an x in it.
I am pretty certain you have a card in your computer for it mentions a 7.1 speaker system.
If you put your service code in to do a search for drivers you will get the correct ones for your particular machine. Download install and reboot.
If you are not using six speakers and one sub woofer then the pink one in the back is the mic
SOURCE: i lost my motherboard cd for my dell optiplex 330
All drivers for your model can be found here.
