I can print through Network it is working fine. But when i m trying to access through web with IP address the message "RemoteUI Contents is Not Found!!" received. Please help.
Remote UI probably has not been installed on copier. Get a technician to come out and use SST to load RUI onto your copier. They should upgrade firmware to latest version at same time.
Don't forget you can also pull scan over the network using Canon Network ScanGear Tool in case you would like to scan.
HP says to use the Vista drivers. You have to install it a a local printer follow these steps....
1. Make sure the printer is turned on and connected to your network. Verify that you can access the printer's internal web page by browsing to its IP address before continuing. Print a network config page or make note of the IP address and Name. (should be a static IP)
2. Click >> Start >> Control panel >> Devices and Printers.
3. Click the Add a printer
4. Select Local printer
5. Select Create a new port and select Standard TCP/IP Port and click Next button.
6. Under Device type, select TCP/IP Device. Under Hostname or IP address, enter the printer's host name (found on the printer's network configuration report the generated above). Click Next.
If you get a message about Additional Port Information Required, then the printer was not found using the host name. You can go back and retry or using the printer's IP address instead of the host name.
7. Select HP or Hewlett-Packard from the list of manufacturers and select and select your printer model. Click Next.
If your printer model was not listed, then select Have Disk, browse the HP CD that came with your printer and select the first file that starts with hp and ends with inf.or use currently installed driver if you have teh correct on installed. Click Open then OK. Select your printer model. Click Next.
8. It will ask for the Printer name -- enter a new name or use the existing one. This will be the name of the printer that you select from other applications.
9. You may be asked to share the printer. Make a choice and click Next.
10. The Print Test Page box appears. Go ahead and print it.
11. Click Finish.
same
network printing wors fine, but when attempting to access the web tool via ip-address the error "RemoteUI Contents Not Found" is displayed.
